Old 04-26-2006, 11:35 AM   #1
Kai
Kai's Avatar
Kai is on a distinguished road
Default Tyre Recommendations
Finally having gotten money, i've put the car into have the clutch changed, and i've decided to invest in a pair of tyres to replace the worn rear ones (2.2mm tread). I've just paid ?116 for a pair of Nexen N2000's in 225/50/16 V, however, the tyres on the front are a pair of bridgestones with at least 5mm of tread left. Seeing as they're a more well known brand, should i put the new ones on the back, or rotate them, giving me the part-worn bridgestones on the rear and new N2000's on the front?
Just for clarification - these are the ones i bought: http://www.nexentire.co.kr/english/p...N2000&expend=1
Kai is offline   Reply With Quote
Old 04-28-2006, 01:41 PM   #2
KNYFE
KNYFE's Avatar
KNYFE is on a distinguished road
I like the tread pattern on those ALOT!! I'd put the new on the back unless you want to replace the others fairly soon. I have usually experienced the wheels under power wearing more quickly then the other two. Either way would work but the whole idea of new tires is more traction so I'd put them on the back.
http://www.cardomain.com/id/FastnLowI30
Supra, I30 and A8 are above...
KNYFE is offline   Reply With Quote
Old 04-28-2006, 08:09 PM   #3
Kai
Kai's Avatar
Well, i put them on the back because yes, common sense kinda dictated it...
However, because i had the clutch and the tyres done at the same time, I have a slight problem. At 30mph and under, theres a vibration, kinda rumble and you can easily feel it when you're sat in the drivers seat. Could the clutch be misaligned, or could the tyres be improperly balanced?
Old 04-28-2006, 08:22 PM   #4
KNYFE
KNYFE's Avatar
Go back to the garage where it was done. Have the alignment/tire guy go for a ride with you. He will be able to tell you immediately.
Old 04-29-2006, 12:07 AM   #5
Kai
Kai's Avatar
Hrm - not possible. At least not at this place. It's just a tyre place just off the A1010, and all they do, is fitting tyres all day and supplying them. I'll take it to another Tyre place on monday and pay ?50 for the privilege of being told 'those tyres are crap' or something :S
Aftemarket wheels and tires for roadracing JPDsupra MKIV FAQ 16 08-30-2013 12:23 AM
recommendations please Mike S> MKIII Supra 0 04-22-2007 01:12 AM
Pistons Recommendations Bill UK MKIII Supra 0 08-02-2006 12:15 PM
mk3 tyre pressures wesbam1 MKIII Supra 2 04-30-2006 06:58 AM
