Old 05-02-2006, 02:31 PM   #1
barton
barton's Avatar
barton is on a distinguished road
Default HELP!: 7MGTE engine block info needed
Currently rebuilding a 7MGTE 3.0 Turbo engine. Got it all stripped for inspection and found that almost every component was knackered. So, bought another complete donor car and started again. All these parts are OK, but while the engine I started with was from a 1992 car (and so has oil spray jets mounted in the oil gallery inside the block, to cool/lubricate the little end bearings and piston undercrowns) the one I'm rebuilding now is from a 1989 car, and doesn't have the oil spray jets. I salvaged the jets before scrapping the knackered '92 block, but my machine shop aren't exactly sure where to drill and mount them in the '89 block. Can anybody supply me with an image/schematic or scan from a workshop manual (showing the jets in situ or removed from a later type block) in order to help clarify this point. It'd be much appreciated.
barton
View Public Profile
Send a private message to barton
Send email to barton
Find More Posts by barton
Add barton to Your Buddy List
barton is offline   Reply With Quote
HELP!: 7MGTE engine block info needed barton MKIII Supra 1 05-19-2010 05:54 PM
Engine swap info needed supraman121 MKIII Supra 0 12-07-2006 05:13 AM
