Old 05-21-2006, 06:30 AM   #1
Bigjig
Bigjig is on a distinguished road
Default HELP 5m parts 4 a ma70
i need some help i need to no if a
5m bellhousing will bolt up to a 7mgte motor
the gearbox is in a toyota celica its a w58 and the engine is
a 5mge. Im want to no if i brought this car, would
i have everythink i need, any help would be great cheers.
Bigjig is offline   Reply With Quote
Old 05-21-2006, 04:07 PM   #2
Burn N' Up
Burn N' Up's Avatar
no idea, sorry
Old 05-23-2006, 12:07 PM   #3
barton
barton's Avatar
barton is on a distinguished road
Wink
Yes, because the 5m and 7m block castings are the same, as are the bolt patterns for the bell housings. I've got a Celica Supra mkII, which I'm putting a 7mgte motor in but keeping the 2.8 w58 gearbox.
you'll need to use the friction plate from the 2.8 set-up, so it fits the w58 input shaft, but as for the cover: ideally it would be the from 7m so it can bolt to the 3.0 flywheel, but the 3.0 cover is a big heavy cast item and with a built in thrust bearing- i haven't solved this problem myself yet, as am still rebuilding the turbo motor, but am hoping the 2.8 clutch cover will fit the 3.0 flywheel, and be strong enough: maybe someone else can shed some light on this, 'cos I'd like to know too.
hope this helps
Barton
barton is offline   Reply With Quote
Old 05-23-2006, 07:45 PM   #4
Bigjig
so if i was to buy a celica supra with a 5mge with w58 gearbox
to go into my mk3 ma70.
which parts would i b able to use and which parts would i have to
buy.
so the gear box bolts up
do i need to get a ma70 turbo flywheel?
clutch?
p.plate?
driveshaft?
clutch pedal?
cheers 4 your help:}
87 MkIII vs 89MkIII -- parts interchange willblock MKIII Supra 5 07-24-2016 06:27 PM
