Old 05-16-2006, 01:29 AM   #1
supfoo514
supfoo514 is on a distinguished road
Default cost?
I did a search on the forums and found that to change a BHG on a turbo supra is around 1700?? I was just wondering if that would include a water pump and timing belt change? And also is there anyway for me to lower the cost of the job without having to do it myself because I'm not too capable around fixing a BHG and would probably make things worst. Thanks.
91 Turbo Automatic MKIII
a.k.a "Sammie"
supfoo514 is offline   Reply With Quote
Old 05-16-2006, 04:13 AM   #2
stumpjumper
stumpjumper is on a distinguished road
Sorry to tell you, but this is an expensive fix. It's mainly labor because it takes a lot of time to take all the crap off and on again. TOok me about 14 hours, I know that is a bit much compared to a mechanic. Expect about 8-10 hours worth of labor minimum.
That price probably includes water pump and such, but I doubt they are toyota parts.
stumpjumper is offline   Reply With Quote
Old 05-16-2006, 04:23 AM   #3
mrnickleye
mrnickleye's Avatar
Water pump & timing belt are generally NOT included in a BHG job on 7Ms.
That price would include a valve job, and pressure testing the head, and milling the gasket surface.
Stick to a regular headgasket for this type of work. Metal gasket should only be used when the block is out and gasket surface is milled to a very fine finish. (for high HP people).
Plan on useing ALL new hoses to.
Old 05-17-2006, 02:16 AM   #4
supfoo514
thanks for the info. my friends dad owns a shop so ill see if i can get a good price from them..... hope its not too much cause i cant afford something that expensive
a.k.a "Sammie"
Old 05-17-2006, 02:39 AM   #5
mrnickleye
mrnickleye's Avatar
Default OEM gasket set.
Check this.....
http://www.thepartsbin.com/repsite/l...t~reparts.html
I used this set. Its made by Ishino, of Japan. I researched out gasket set for a long time before I did my own BHG job. This company has been the main OEM supplier to Toyota, Nissan, Mazda etc. forever.
The gasket has gone thru a few improvements since the original.
Surface prep it very important !!!
Some other company also buys this set from Ishino, and packages it in their own. Can't remember name, think it starts with a 'C'. So if you order the set, and the package says something else on it, it still Ishino inside.
Old 05-18-2006, 03:37 AM   #6
supfoo514
thanks for the link...but i dont think im gonna be able to do the head gasket myself...thats why i want to find out how much it would cost to have it professionally done...I lack the mechanical skills to do the job myself...but i appreciate the info none the less.
a.k.a "Sammie"
BHG cost of repairs adam0001 Non-Generation Specific Questions 8 10-27-2008 11:40 PM
how much wat it cost to buy and install a 1jz? 5upra lov3r MKIII Supra 2 09-08-2008 11:33 PM
