Old 06-08-2006, 03:12 AM   #11
Supra2NR
Supra2NR's Avatar
i had the same discussion with sum guys that have been owning a supra for years in chicago,, i askd them if its possible and yes they did tell me its possible but
like everybody has told u already u have to f*** wit the firewall and the harness,, so ur left with two choices then,, the 1jz or the 7mgte
the perks of a 1jz is it can handle more abuse but not that much and its so hard looking for parts, not to mention more expensive, plus dont get a jdm engine ,, its more headache than its worth jus look for a 7mgte and replace with a metal head gasket , and youll be good to go all you need is the stock manual transmission from another turbo
Year to Year MGE Swap changes Mr.Bojangles MKIII Supra 6 01-10-2008 07:44 PM
1JZGTE swap question supradaddy0803 MKIII Supra 1 04-12-2007 04:56 PM
to swap or not to swap edelmar417 MKII Supra 16 04-10-2007 12:06 AM
NA->T swap and convertion questions 5+4=9 MKIII Supra 6 03-02-2006 02:11 AM
89 NA => Turbo SWAP INFO akadiablo MKIII Supra 0 12-09-2005 06:21 AM
