Old 05-23-2006, 11:59 PM   #1
91_7mgte
91_7mgte is on a distinguished road
Default need help supra over heat
hi, i'm new to supra forums and i just got my 91 supra but i't is over heating. i don't know why it's overheating. i have replace the waterpump, thermostat so i think it's the fan clutch. well this is how the car overheat. the only time it well overheat is when it's on the freeway go 70 to 80 mph. the reserve tank would be full of hot coolant and when you take off the cap there would be steam and every morning when i start the car i can hear water running behind the dashboard. anybody know what wrong with the car.
91_7mgte is offline   Reply With Quote
Old 05-24-2006, 12:23 AM   #2
joel w
joel w's Avatar
Is it loosing coolant? It sounds like a blown head gasket and the exhaust may be entering the coolant system? It could be a few things. Sorry to be the bad news guy..
They sell a kit that detects exhaust gasses in the coolant that might be worth picking one up.
Take a read though this thread.
http://www.toyota-supra.info/forums/mkiii-faq/13-help-my-car-is-overheating.html
Old 05-24-2006, 02:04 AM   #3
theWeezL
theWeezL's Avatar
often overlooked item is the radiator cap...they are designed to maintain pressure to a certain point, then open up to relieve the pressure if it gets to high. If its old and weak it can actually not hold any pressure therefore allowing your coolant to boil and overflow. Its also like a 5 dollar part and worth trying
Old 05-24-2006, 02:39 AM   #4
joel w
joel w's Avatar
^^^Good call, I assumed that was in the link but i do not see it..
Old 05-24-2006, 03:13 AM   #5
1988gte
1988gte is on a distinguished road
my cap had the gasket torn and cracked never lost water or heating problems after the replacement cap
1988gte is offline   Reply With Quote
Old 05-24-2006, 03:26 PM   #6
ddmcse
ddmcse's Avatar
you better hope it's the cap and get one from toyota not a parts store
you might pay 7-8 bucks more from toyota but spring for it .
the water rushing sound in the morning is from the lack of the proper water level
get the new cap , top off the coolant , i would park the car on a serious incline to try and get any and all air out of the coolant system .
if you lose more water and hear the rush again you have a BHG
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 05-24-2006, 08:32 PM   #7
G-string
G-string's Avatar
G-string is on a distinguished road
Man blowen head gaskets are sutch a problem why couldnt they have just made them work better
to much pizza makes me feal sick
G-string is offline   Reply With Quote
Old 05-24-2006, 09:11 PM   #8
joel w
joel w's Avatar
^^ Part of the problem is the factory head bolt torque specs were too low.
I have another theory that the lack of a "bridge" accross the water jackets around the cylinder walls on the block also contributes to this at higher boost levels.
Looks at the JZ block pictures sometimes and you will see they added "bridges" across the water jackets..(not many bhg's)
This is just my opinion..
Old 05-25-2006, 03:00 AM   #9
kwnate
SP58GT
I had the same issue, turns out I had a cracked coolant line. It was one of the small lines leading to the throttlebody. It was a hard one to spot, inspect all the little hoses around the engine. Good luck
Nate
Old 06-08-2006, 10:43 PM   #10
91_7mgte
thanks everyone for you help but i found out why my car was overheating. the radiator was bad that's all.
86 supra MK II no heat bigtime337 MKII Supra 0 11-06-2008 12:12 AM
Heat Consistancy Issues Chambers MKIII Supra 14 04-07-2008 12:52 AM
