Old 05-28-2006, 03:19 AM   #1
supfoo514
supfoo514 is on a distinguished road
Default I can't get my air box off!!
Okay.. so I was trying to get my airbox off to change my air filter but the bolt that connects it to the radiator support won't come up. I tried WD40 and got the bolt to turn but it won't come up. I don't know whats wrong. I tried to push the washer up a little bit but it still didn't work. It just turns and doesn't come up. Any suggestions? Thanks.
91 Turbo Automatic MKIII
a.k.a "Sammie"
supfoo514 is offline   Reply With Quote
Old 05-28-2006, 04:41 AM   #2
Wink Little trick
Sounds like you have a stripped bolt, or hole. Try to stick a flat blade screwdriver under the head, or washer, and pry upward while you turn the bolt.
Old 05-29-2006, 01:53 AM   #3
h8z2luze
h8z2luze's Avatar
Is there a nut on the otherside?
Old 05-29-2006, 06:15 AM   #4
yea maybe the welded nut has broken off
or try mrnickleye's idea
Old 05-29-2006, 07:38 PM   #5
supfoo514
I don't think there is a nut on the other side because I took the other bolt off with no problem. And I checked to see if there was a nut. I guess I'll try the screwdriver trick.
a.k.a "Sammie"
Old 05-29-2006, 11:10 PM   #6
rnoswal
rnoswal's Avatar
Well usually it is a blind nut on the other side of the sheet metal that is welded on so you won't have to hold the nut while taking out the bolt, but sometimes that nut breaks is weld and turns with the nut. I agree with the others as far as stripped out threads half way on the bolt. You may have to cut the head off and use a center punch to hit it out from the top if the screwdriver trick doesn't work. But prying up the bolt while unscrewing should do it.
Russ
