Old 05-30-2006, 06:11 AM   #1
PsychoDad
PsychoDad is on a distinguished road
Default Car sounds like CRAP!
i own a hand me down 87 na supra. whenever i start it, it sounds horrible; as i drive off from wherever, it sounds similar to the wheel of fortune wheel except louder...quite embarrassing, i have no clue why(tho im guessing exhaust problems). after a few minutes of driving it sounds ok, but it has to "warm up" or something i'm not sure, and i dont like the idea of sounding like $hit for 5 minutes before sounding normal. if anyone has an answer pls let me know.
PsychoDad is offline   Reply With Quote
Old 05-30-2006, 06:19 AM   #2
Kai
Kai's Avatar
Kai is on a distinguished road
It could mean several things - although personally i'd go with:
a) Oil pressure low until the engine heats up and the oil thins out (you have crap oil)
b) Valve Clearances need adjusting
Kai is offline   Reply With Quote
Old 05-30-2006, 11:06 AM   #3
IHateHacks
IHateHacks's Avatar
I would place my bet on a blown exhaust gasket. Either manifold to head, manifold to down pipe (front pipe), or front pipe to cat. But, 99.9999% of the time the exhaust gasket blew because it overheated and warped the gasket surfaces. I'd say either the exhaust manifold or head surface is warped.
Or (as it was in my case) theres that .0001% chance there are one or more stripped threads where the exhaust manifold bolts to the head. I had to helicoil 3 on my supra.
Same thing happened to me when cold, tickin like a ford; when warm, pretty much ok. That is because the basic law of physics or whatever states that as a molecular structure retains heat, it expands (in an exhaust manifolds case it fills in the imperfections of a warped surface) and as a molecular structure cools it contracts. And im not saying it fills it in perfectly and it depends on how bad its warped.
Good luck!
weird sounds when car moves Donovan MKIII Supra 10 06-08-2007 11:14 PM
Car runs like crap, spits, sputters etc! HELP Z'mnypit MKIII Supra 36 05-18-2007 10:39 PM
supra problems weird sounds please help Donovan MKIII Supra 13 05-12-2007 06:34 AM
bad sounds Jeff_5_7 MKIII Supra 3 04-24-2007 05:53 AM
SS autochrome manifold crap?? roadracer4life MKIV Supra 2 01-25-2007 01:22 PM
