Old 08-24-2004, 04:48 AM   #1
somkeat
Guest
Posts: n/a
Exclamation Differential Ratio
How I can know differential ratio of 7M-GTE engine.Because my cars was change engine from cougar to 7M and diff. can not match with transmittion.
Thank for your answer.
Somkeat.
Old 09-18-2004, 11:49 AM   #2
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
hey
to check the ratio of the diff the way i've always checked them is......
place a chalk mark or something easy to see on the driveshaft end of the diff and a chalk mark on the top center of one of the side axles on the diff
see how many times it takes to turn the driveshaft end till the chalkmark on the axle bit comes to the top again...
generally 7mgte diffs 86-88 are 3.9 lsd and 89-92 are 3.7 i believe...
so generally you would have to turn the driveshaft end of the diff 3 times and almost one more rotation to get the ratio
let me know how you get on or if my instructions totally don't make sense lol
also.. what do you mean you can't match it with the transmission?
thanks
Pics of my build.
Do a diagnostic first!
Old 09-29-2004, 03:57 AM   #3
MA70-1JZ
MA70-1JZ is on a distinguished road
Have a look on the build plate of the car..various differential codes mean different ratios..Once you know the code on the build plate look it up on the net. I am sure that you will be able to find it out from here
MA70 widebody-1jz conversion with R154, HKS Type S intercooler, Tein HA coilovers, Apexi PowerFC, HKS step one Cams painted in AudiTT Blue
MA70-1JZ is offline   Reply With Quote
Old 09-29-2004, 07:45 AM   #4
suprra_girl
7M POWAH! ;)
lol
the engine and diff is a replacement for a cougar lol
if it has the transaxle code for the 7m in it i'll be highly surprised :P
Pics of my build.
Old 06-06-2005, 04:23 AM   #5
mrnickleye
mrnickleye's Avatar
Speaking of Diff ratios....has anyone swapped a diff from an N/A into a turbo ?? I believe I read on some website that the '89 N/A (mine) has 4.33/1...and the turbo had 3.7/1. I wonder if it would give the turbo version a better 'holeshot' on the dragstrip ?? or just be too low??
Old 06-06-2005, 07:17 AM   #6
suprra_girl
7M POWAH! ;)
well it has been done.... and out of the hole it is really good... but you may run out of legs
it should go alrite
Pics of my build.
differential swap or not kkiepvvessau MKIV Supra 22 09-02-2008 01:55 AM
MKIII Differential SupraSleuth Non-Generation Specific Questions 3 08-06-2008 02:44 AM
Rear differential question finaltable MKIII Supra 9 11-13-2007 07:49 PM
limite slip differential suprabahamut MKIII Supra 0 08-22-2007 04:08 AM
Differential gearing changes? jibbby MKIV Supra 0 02-23-2006 07:51 PM
