Old 06-02-2006, 01:45 AM   #1
White87Turbo
White87Turbo is on a distinguished road
Default Boost= Less Power
So I just recently started having this problem and cant quite figure out what it is.
I have an 87 Turbo and when i get in 3-5 gears it will only go about 2000 RPM and then it will not want to go any faster even if i floor it. Im making boost and it seems to slow me down when i hit it. Im running everything stock except for exhaust (which i took off and it is not clogged) and a Cold Air Intake.
My guess is that it has something to do with the computer because i rechecked the wires and everything.
Has anyone else had this problem or would have any ideas how to fix it.
White87Turbo is offline   Reply With Quote
Old 06-02-2006, 11:10 AM   #2
have you done a diagnostic yet
i would say code 34 will be in there
Old 06-02-2006, 02:51 PM   #3
Thumbs up
i think it's a popped hose .
cracks in the black hose connecting the 3000 pipe to the throttle ?
Old 06-02-2006, 08:27 PM   #4
White87Turbo
The codes i have are 34- Abnormal Turbo Pressure
51- Idle Sensor
52- Rod Knock Sensor not reading
I dont think its has a crack in but ill have to recheck it.
Old 06-02-2006, 09:33 PM   #5
then suzi is right and you are hitting fuel cut off ?
Old 06-02-2006, 11:27 PM   #6
find your boost leak and repair as necessary
usually the one from the turbo to intercooler is one of the main culprits and as mentioned the pipe between the 3000 pipe and throttlebody
have fun finding it
Greetings! importauto Import Auto Center 7 06-21-2009 07:42 AM
no spark chrism8799 MKII Supra 6 12-08-2008 12:38 AM
getaway in stockholm... (i think thats how you spell it) kelogg Road Racing & Autocross 3 06-03-2008 10:53 PM
Lsd RussianMK3 Drifting 6 12-10-2006 05:42 PM
MEET UP's TEAM_Bastos Drifting 0 03-02-2006 09:09 PM
