Old 06-06-2006, 10:28 PM   #1
Sharaz508
Sharaz508 is on a distinguished road
Exclamation Question about clogged cat
Would a clogged cat make my car backfire while driving and at idle?
Sharaz508 is offline   Reply With Quote
Old 06-07-2006, 03:14 AM   #2
jfunez
jfunez's Avatar
actually a clogged cat would actually make your car run like crap, even at idle ,specially under acceleration....If you could borrow a back pressure tester gauge from somebody you could get that possibility out of the way....Its easy to test..if you need any help let me know...
Old 06-07-2006, 03:21 AM   #3
mrnickleye
mrnickleye's Avatar
Timing off can do it. An exhaust leak can do it. A sticking open injector can do it (raw gas down the exhaust).
Old 06-07-2006, 03:05 PM   #4
Sharaz508
it idles fine just back fires a little. But it does run like crap its a 5 speed and when i start to move the car starts bucking (and i no how 2 drive standerd). its does that till like 2000 rpm then it runs a little better but then after that it runs like shit agian. It back fires when im driveing to. But it does have an exhaust leak it needs an exaust pipe gasket but i dont think it would make it run this bad. Ill be going down the street then floor it and it will speed up but harrably. it cant be spark plug (irridium) or the plug wires becasue there where just changed recently.
Im ganna try and test the back pressure. what should it be?
Old 06-07-2006, 08:31 PM   #5
mrnickleye
mrnickleye's Avatar
Well now you have given us more info. runs poorly, not just backfiring.
If its N/A, Cap & Rotor = replace !
Misfiring is your problem. Why is the question. Could be a lean fuel condition.
Old 06-08-2006, 01:47 AM   #6
Sharaz508
How could i tell if its a lean fuel condion? and what should i do?
Old 06-08-2006, 02:25 AM   #7
jfunez
jfunez's Avatar
if u get your hands on a backpressure tester ,hook it up on the o2 sensor orifice before the cat. I cant remember but it should be in the low 0 to maybe 3, cant remember but it pretty much should be steady on the verry low also during acceleration, there should not be much fluctuation on the gauge under accel..
Old 06-08-2006, 12:41 PM   #8
rnoswal
rnoswal's Avatar
First do a tune up! Plugs, wires, cap and rotor. Most of the time that is all it is. If you have a cylinder or two that aren't firing, it will have no power and buck and backfire. Try that simple stuff first then see how it runs. Air filter too.
Russ
Old 06-08-2006, 01:46 PM   #9
theWeezL
theWeezL's Avatar
is your car throwing any codes (engine light is on)?
if not then I agree, do cap and rotor, check your timing, check all your vacuum hoses for cracks or missing connection, replace your fuel filter, and perhaps test your fuel pressure.
if you still cant solve the issue, sometimes its nice to take it to a mechanic for a scope check. Its usually a reasonable fee and a good mechanic can usually figure out whats wrong for you. Then you can do the work yourself to save money.
Anyway, just a suggestion
____________
Old 06-08-2006, 07:25 PM   #10
Sharaz508
no codes but i think i narowed it to a boost leak and it must be giving my car to much gas and not enough air because the air goes in the MAF then most of the air must come out some where on the way from the turbo to the intake manifold. But would it make my car flutter or wanna stall when i get on it or start moving? i got it up 2 around 5-6 rpm and the boost only goes to 4-5 psi
Question about 7m-gte. AzNbOi2626 MKIII Supra 3 03-29-2011 06:55 PM
Starter Removal question OkieRA29 MKIII Supra 13 05-11-2010 12:08 AM
Pre89 versus 89+ nose and support. lifesnotfair MKIII Supra 2 01-08-2010 09:06 PM
Help! Question on front NOSE and bumper supports. lifesnotfair MKIII Supra 1 12-26-2005 03:54 PM
Quick question AutoXMan MKIII Supra 12 09-30-2005 06:40 AM
