Old 06-11-2006, 10:54 PM   #11
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
then i would say it's the hard coolant line underneath the manifold bolted to the block has gotten a pinhole or cracked or something, you could try looking at it with a mirror or you will need to remove the exhaust manifold to clearly see
it could be the front flange where it bolts onto the back of the front timing cover, that gasket may have let go
have a good look with a mirror all around therer and see if you can see any leaks
Pics of my build.
Do a diagnostic first!
Old 06-12-2006, 06:03 AM   #12
Rommy
Rommy is on a distinguished road
Originally Posted by theWeezL
just thought of another diagnostic question to ask...what does the vapor smell like? Coolant has a sort of sweet smell to it, oil burning is acrid and obviously petrolium based, and powersteering fluid or ATF is kind of a sharp sweet petrolium smell.
what does yours smell like?
It's definetly not coolant. It's either power steering fluid or oil. I'm not sure it's oil though, as oil usually has a stronger smell; this has, like you said, a half oil/sweet smell.
I'm going to have my mechanic check it out this week and see if he can do something about it. I have to change the power steering line either way, I'm putting a bottle of fluid every week as it is, dripping like crazy.
1990 N/A Automatic Supra. Red.
No mods. Engine needs repair first.
Anyone want to sell me dash trim piece? Mine is falling apart.
Rommy is offline   Reply With Quote
Old 06-12-2006, 07:22 AM   #13
theWeezL
theWeezL's Avatar
gotta be a PS line somewhere then...they do criss cross under the engine. Maybe its a pinhole in the high pressure line and it squirts onto the exhaust manifold from time to time.
____________
Old 07-25-2009, 09:05 AM   #14
cheshire1369
cheshire1369 is on a distinguished road
white smoke could be a sign that it is running to rich (too much fuel per air ratio), while it is a simple fis, ie recalibrating injectors, to just changing the air filter... to long like that will cause it to run at a higher temp, causing probs down the line, to keep a supra happy, change filters, oil, and sparkplugs regiliously! should keep probs to a bare min
cheshire1369 is offline   Reply With Quote
Old 07-25-2009, 10:01 PM   #15
Rommy
Wow, holy old thead!
I haven't had the Supra for years, haha. Didn't even think this thread still existed.
Old 07-26-2009, 06:32 PM   #16
corrosivecopper
corrosivecopper is on a distinguished road
Default manifold smoke
Ya said you took the manifold off? Perhaps I misunderstood.. nonetheless, could you notice any cracks in the manifold? Sounds like exhaust maybe leaking, and something like that shouldn't interfere too much with emissions
corrosivecopper is offline   Reply With Quote
Non Turbo JZA80 Exhaust Manifold SupraJAZ MKIV Supra 3 04-19-2007 12:19 PM
White Smoke Drag0na5h MKIII Supra 1 04-25-2006 06:36 AM
NEED HELP...Does white smoke = BHG? 87sleeper MKIII Supra 10 01-11-2006 12:38 AM
