#1 |
sounds like a blown headgasket. have you done a compression test?
#2 | |
![]() Quote:
Only thing I'm leaking is power steering fluid, but that's another story.
1990 N/A Automatic Supra. Red. No mods. Engine needs repair first. Anyone want to sell me dash trim piece? Mine is falling apart. |
#3 |
A friend told me it could be the exhaust manifold gasket. Is that a possibility? It's coming from like, right there.
#4 |
While the smoke could be from the powersteering fluid burning off on the exhaust, it wont effect your preformance.
Perhaps you have two different problems. Are you losing oil or water? is your oil milky? are you getting white smoke out the end of your exhaust? If you answer any of these questions yes...you have a BHG. however if you answered no to all of them, then you have a more preplexing proplem. You say you see smoke out from under the exhaust manifold shield? Have you tried taking this off to get a better look? The lack of power may be a completely unrelated issue, but start with your outward signs and work it from there.
____________ Eagles may soar, but weezl's never get sucked into jet engines! ![]() |
#5 | |
![]() Quote:
I'm not losing oil or water. Absolutely no leaks whatsoever except the power steering fluid. I took the exhaust manifold shield off today, and there was white smoke coming from right under the manifold. On the right side was the most obvious, when the car was hot, it would be steaming right out of there. I DID see some white smoke coming out of the exhaust, but that was when we first started the car early in the morning. Might've just been the weather/cold car. I don't see how the power steering fluid could be dripping somewhere where it could burn, though. Oh, I just remembered. If I had a BHG, would I still pass smog? Because I'm in California, and I passed smog the other day with no problems whatsoever, my emissions were actually lower than average.
1990 N/A Automatic Supra. Red. No mods. Engine needs repair first. Anyone want to sell me dash trim piece? Mine is falling apart. Last edited by Rommy; 06-09-2006 at 03:06 AM. |
#6 |
Well the smoke has to be some kind of fluid vaporizing, so PS seems like the most likely culprit. dunno how it could be getting there, but what else could it be?
#7 |
7M POWAH! ;)
could be the distributor seal leaking oil onto the manifold?
does it look like it's coming from below the manifold and up or what?
Please use the forum to ask your questions as they will get replied to much faster than pming me ![]() Pics of my build. "Good girls are just bad girls that don't get caught" ![]() Do a diagnostic first! |
Non Turbo JZA80 Exhaust Manifold | SupraJAZ | MKIV Supra | 3 | 04-19-2007 12:19 PM |
White Smoke | Drag0na5h | MKIII Supra | 1 | 04-25-2006 06:36 AM |
NEED HELP...Does white smoke = BHG? | 87sleeper | MKIII Supra | 10 | 01-11-2006 12:38 AM |
