Old 06-20-2006, 03:12 AM   #1
h8z2luze
h8z2luze's Avatar
h8z2luze is on a distinguished road
Default Fan?
I was thinking about taking the clutch fan off and installing an electric fan. Has anyone done this? Seems like it would be more effective and save some hp not much of corse. Mostly to keep cool. I dont know how you would hook it up though unless you had a toggle switch. Or hook it up to run all the time. My friend has that on his car. He wired it into the ignition switch.
1989 Supra 7MGE MK3 5-speed project...
http://www.cardomain.com/ride/2385505
h8z2luze is offline   Reply With Quote
Old 06-20-2006, 10:24 AM   #2
ddmcse
ddmcse's Avatar
Cool
i wired my electric fan into the existing a/c fan wiring
the fan is close to 3000 cfm
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 06-20-2006, 07:38 PM   #3
h8z2luze
h8z2luze's Avatar
Its ok only comming on when the a/c fan is on?
Old 06-21-2006, 04:51 PM   #4
f00g00
Which fan?
I just tried a failed experiment with a mustang electric fan. I bought it for about 100 dollars new with shroud, measured and cut with my spare radiator and when it came time to install it there was about 1/2 inch less room than I needed.
Old 06-30-2006, 03:36 AM   #5
h8z2luze
h8z2luze's Avatar
What about this fan? It seems like a good deal. What do you guys think?
http://cgi.ebay.com/ebaymotors/ws/eB...MEWA%3AIT&rd=1
Old 06-30-2006, 09:58 AM   #6
f00g00
That 10 inch fan is way too small and there isn't a big enough shroud area for it to cool the whole radiator. If you made a custom shroud and had two of those then maybe. If your worried about how to run the fan you could buy a universal Thermostatic fan control. It has a heat sensor to turn the fan on however you adjust it.
Im taking my mustang fan to the USA in less than a week and its going on my 72 K5 Blazer. The Flex-A-Lite twin fans are coming back here to go on my Supra. It gets damn hot over here so I hope it will be enough.
Old 06-30-2006, 11:53 AM   #7
rnoswal
rnoswal's Avatar
Get the 16" fan and buy the remote/adjustable fan relay from Hayden. You can get this part at almost any parts store. It runs directly off the battery, but you can run it to the ignition switch if you don't feel comfortable about it running after you switch the car off. I have this on my daughters Supra and it works just fine.
Russ
Old 06-30-2006, 06:41 PM   #8
h8z2luze
h8z2luze's Avatar
Cool thanks a lot. What would I do without you guys?
Old 06-30-2006, 09:35 PM   #9
theWeezL
theWeezL's Avatar
buy a Honda?
____________
