Old 06-22-2006, 01:54 PM   #1
dedbonz666
dedbonz666 is on a distinguished road
Question I tried some old threads
My car is running great now, timing and idle a little high, but after a good warm up and letting it sit for 10 min or so, it wont start. I have BG injector cleaner in it now and sea foam in the crank case... oil change coming Saturday. I've done sweep tests on my AFM and TPS, they seem good. I believe I'm getting spark from my ignitor and coil. Any ideas other than these? You guys have helped so far, Thanx
Bert
dedbonz666 is offline   Reply With Quote
Old 06-22-2006, 03:14 PM   #2
theWeezL
theWeezL's Avatar
wont start how? wont turn over, wont fire? please be more descriptive.
if you mean wont fire, check for spark first its the easiest to do. Pull a spark plug out, put the plug wire back on it, ground the threaded part against the engine, and have someone turn over the car...
do you have spark?
____________
Old 06-23-2006, 12:28 AM   #3
mrnickleye
mrnickleye's Avatar
The temp sender for the computer may be disconnected or bad.
Transmission threads are bored out. mkiiisupra MKIII Supra 17 04-08-2008 11:46 AM
people ditching there threads supra_91 Off Topic Forum 2 09-22-2007 02:56 AM
Spam and Sex Threads mrnickleye Off Topic Forum 5 09-11-2007 04:35 AM
What threads to read first? mikegladsz Off Topic Forum 1 02-02-2007 02:20 AM
