Old 06-23-2006, 07:01 AM   #1
sd88supra
sd88supra is on a distinguished road
Default codes 51 and 71
well, i adjusted my tps, and code 51 went away, but so did code 71 (EGR system malfunction). the only thing i had done to 71 was change the temp sensor. however, i did that before i adjusted my tps and code 71 stayed (yes i remembered to erase the code). in fact, i got the same thing on two different occasions. but now that i fixed 51, 71 went away. how can a maladjusted tps throw off an EGR code?
sd88supra is offline   Reply With Quote
Old 06-23-2006, 05:17 PM   #2
joel w
joel w's Avatar
I am not sure it can, but code 51 can effect a few other things like base timing.
I would install the daig jumper and verify your timing is at 10 degrees for starters..
Error Codes 42 and 43 Getphazed MKIII Supra 6 09-14-2008 10:32 PM
Codes 25,26,51! justin1642 MKIII Supra 11 08-30-2007 08:08 PM
codes 22 24 31 kidthunder650 MKIII Supra 16 04-12-2007 11:54 PM
Got Codes? h8z2luze MKIII Supra 14 08-29-2006 01:48 AM
fault codes on a newly re-headed supra lethalwithasupra Non-Generation Specific Questions 5 09-28-2005 08:22 AM
