Old 07-09-2006, 07:33 PM   #11
rnoswal
rnoswal's Avatar
I bought a carrier bearing, but it was for the MK11 or similar, none for the MK111. Just the rubber part seems to wear out mostly so I just took my old one apart along with the new one and swapped the pieces. Still not the perfect solution, but it helped. It is too bad that one of the most worn out parts on the car is that part and no one makes a replacement for it. Unless of course you are willing to buy a one piece shaft for 2 or 3 hundred and do away with the carrier bearing for good.Russ
Old 07-09-2006, 08:43 PM   #12
Isphius
Isphius's Avatar
thats what i would do /\ lol. Mine seems to be fine @ 190k miles, although i do get a little bit of transmission vibration (through the shifter) sometimes. Maybe its starting to go.
Old 07-11-2006, 04:15 PM   #13
gomezmk
gomezmk is on a distinguished road
I found a dealership that has the carrier bearing but he asked what the bearing is held on by. he said theres two different kinds.
gomezmk is offline   Reply With Quote
spun bearing 91 Supra MKIII Supra 4 10-23-2007 07:58 PM
Center Support Bearing Problem purplescott MKIII Supra 0 03-27-2006 10:17 PM
