Old 06-28-2006, 07:16 AM   #1
skunk
skunk's Avatar
skunk is on a distinguished road
Default jdm swap
Hello
I have an 87 turbo. Im at the tail end of a jdm 7mgte swap(motor goes in on monday), and puck style clutch upgrade. Does any one know if the injectors are the same cc as the american versions. Also do I need a jdm tuned ecu or can I use the american one I allready have. Any SERIOUS INFO someone could give me would be a great help. Thank You
skunk is offline   Reply With Quote
Old 06-28-2006, 04:55 PM   #2
blitzmkiii
blitzmkiii is on a distinguished road
Default Jdm 7m-gte
Wats up? Ive got a Japanesse Designed Motor in my 87 mkiii. 440cc injectors come stock in us version a japanesse. The ecu will probaly have to be tuned because in japan they have no emissions so the car might not run right wit a american tuned ecu.
1987 5-speed Turbo, JDM 7M-GTE, K&N air filter, 3' straight exhaust, Blitz BOV, Upgraded CT26 Turbo, 3' Down Pipe, NGK Iridium Spark Plugs And Wires, Megan Racing Strut Bar
blitzmkiii is offline   Reply With Quote
Old 06-28-2006, 10:33 PM   #3
skunk
skunk's Avatar
well I swaped the intake manafold from my american version and their is a diffrence in the egr. That could effect the cpu. I would like to just block it off, but for now I want to here it run. I think if I keep swaping my parts to the jdm long block it should work the same?? thanks
Old 06-29-2006, 06:25 AM   #4
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
egr does need to be swapped for usdm (if your area requires emissions)
oil pressure sender as ours read in kgcm whereas yours are in psi
possibly change the temp sensors as in 89+ they changed the plug type
throttlebody needs changing as throttle cable/linkages are different
you can use either the jdm ecu or the usdm whichever you feel like
injectors are the same as with the rest from memory
Pics of my build.
Do a diagnostic first!
Old 06-29-2006, 09:46 PM   #5
skunk
skunk's Avatar
Smile
Thanks for the advice, I'll post pics when im done. motor cleanliness, is next to motor godliness.
Old 07-06-2006, 02:44 AM   #6
j3pz
i think this deserves a sticky
Year to Year MGE Swap changes Mr.Bojangles MKIII Supra 6 01-10-2008 07:44 PM
1JZGTE swap question supradaddy0803 MKIII Supra 1 04-12-2007 04:56 PM
to swap or not to swap edelmar417 MKII Supra 16 04-10-2007 12:06 AM
89 NA => Turbo SWAP INFO akadiablo MKIII Supra 0 12-09-2005 06:21 AM
MKIV auto to manual swap?? awd4g63tsi MKIV Supra 0 10-24-2005 08:46 PM
