iv just baught an 87 supra non turbo auto, my problem is when i start it in the morning its fine when it warms up and i turn it off and come back to it 20 minutes later the #1 cylynder misses not the plugs, not the leads, ? im thinkin injecter any help would be great thanks
Put some fuel injector cleaner in. And change your dist cap and rotor. I had this too, i put some paint thinner in the gas tank (probably not good) but it cleaned the injectors right up.
Yay the supra assistant is gone!!! WEEE!! |
ONLY use injector cleaner, because other things like paint thinner will be too harsh on the non-metal parts.
Try some TECHRON. 2 bottles in a full tank. If its fine when cold, can you drive it, and it runs OK, then it gets worse after warmed up?? That would not be injectors plugged. That sounds more primary electrical system. Not secondary (plugs and wires, cap, rotor) How do you know its #1. Does it get a steady spark? You may need to Do a compression test to see where the engine is mechanically. I have seen many cars with one or more injectors plugged. Especially if the car has sat for a long period, months. But a plugged injector is a problem that is present all the time, not just when warm.
Had a Red 1989 N/A. Automatic. Sports Pkg. w/wing. TEMS, and some nice MODS. Sold to a friend 10/08/08. Last edited by mrnickleye; 07-08-2006 at 04:10 AM. |
when i start the car for the first time in the morn it runs perfect and will continue to run perfect as long as i dont turn it off. when i turn it off and re start after say 1/2 hr it misses on #1 and it has lots of spark and i changed the plugs, i even ran it with the #1 spark plug out and no fuel, seems to be lots of compression plug is sparkin away but still misses, then i let it sit for say4 or 5 hours and whala perfect again, the car has had a motor swap from what the previous owner told me, the original motor blew a head gasket and it was cheaper to replace the motor with another used one.
Wow...it sounds almost like my car. Although mine sounds like its just missfireing on ONE of the cylinders....however I didn't know you could run the engine without the spark pluggs in. How do you stop fuel to the cylinder? Or do you not need to to have the engine running when the spark plug is out?
My Ride: http://www.cardomain.com/ride/2351563 Our Supra’s, which art in the driveway, Hollowed be thy power, thy mods are great, thy speed endless, On the road or at the track. Give us this day free of cops, And forgive us our impound charges, as we forgive those who are slow. And lead us not into speed traps, and deliver us from the interceptors, For thine is our car, the power, and the glory…forever and ever….amen. |
#6 | |
![]() Quote:
Starter Removal question | OkieRA29 | MKIII Supra | 13 | 05-11-2010 12:08 AM |
Pre89 versus 89+ nose and support. | lifesnotfair | MKIII Supra | 2 | 01-08-2010 09:06 PM |
Newb Question | powerofZ | Non-Generation Specific Questions | 1 | 09-05-2007 03:22 PM |
Newb with newb questions | 1jzToyota | MKIII Supra | 4 | 11-07-2006 01:24 PM |
Complete Newb Question | Cody7 | MKIV Supra | 8 | 07-21-2006 04:42 AM |
