#1 |
I know there are many posts about BHG but i have looked and i cant find anyone with this problem. ok i start the car it starts great no smoke perfect, i drive it its fine if i dont get on it, when it warms up and i start to get on it, it will puff some white smoke when i stop and drop the rpm's only when i stop, it does not smoke all the time? can anyone help me? not losing coolant either, oil is not milky
#2 |
Dont worry about the smoke. if its a turbo supra then its supposed to do that. mine does it. if no smoke appears at all then you have a problem. if the smoke is white then no problems either. when you see the puff of smoke it means the turbo('s) are warmed up. do you by chance know haw to connect the sppedo cable?
#3 |
Miss Information? Paging Miss Information... Has anyone seen her?
No car is supposed to smoke. Stop posting. If it's white, it's coolant. If it's blue, it's oil If it's black, it's fuel. Because it's so little, it may not appear that you're losing any coolant, but you are. Do a block test. Napa sells a kit as well as many other stores. |
#4 |
This is exactly what my car is doing, how would you fix it though?
#5 |
Perform a block test, compression test, and leakdown test.
You'll find the problem somewhere. Pressure test your cooling system |
#6 |
Thread Tools | |
Display Modes | |
ABS Problem? | rasclaat_98 | MKIII Supra | 6 | 12-13-2010 09:53 PM |
speed sensor problem | nadircicek | Non-Generation Specific Questions | 8 | 10-09-2009 05:58 PM |
found the problem | brs86supra | MKIII Supra | 0 | 05-02-2006 03:42 PM |
Boost Problem, I Guess | nonstop213 | MKIII Supra | 0 | 02-23-2006 07:32 PM |
tsp problem for na t supra | jdlee123 | MKIV Supra | 0 | 09-02-2005 06:01 PM |
