Old 07-08-2006, 02:14 PM   #1
supra8990
supra8990 is on a distinguished road
Default please help me with a problem.....
I know there are many posts about BHG but i have looked and i cant find anyone with this problem. ok i start the car it starts great no smoke perfect, i drive it its fine if i dont get on it, when it warms up and i start to get on it, it will puff some white smoke when i stop and drop the rpm's only when i stop, it does not smoke all the time? can anyone help me? not losing coolant either, oil is not milky
supra8990 is offline   Reply With Quote
Old 07-08-2006, 09:29 PM   #2
travsparky
travsparky's Avatar
travsparky is on a distinguished road
Default dont worry
Dont worry about the smoke. if its a turbo supra then its supposed to do that. mine does it. if no smoke appears at all then you have a problem. if the smoke is white then no problems either. when you see the puff of smoke it means the turbo('s) are warmed up. do you by chance know haw to connect the sppedo cable?
travsparky is offline   Reply With Quote
Old 07-08-2006, 11:56 PM   #3
supra90turbo
supra90turbo's Avatar
Miss Information? Paging Miss Information... Has anyone seen her?
No car is supposed to smoke. Stop posting.
If it's white, it's coolant.
If it's blue, it's oil
If it's black, it's fuel.
Because it's so little, it may not appear that you're losing any coolant, but you are.
Do a block test. Napa sells a kit as well as many other stores.
Old 07-09-2006, 03:52 AM   #4
OmeGa
OmeGa's Avatar
OmeGa is on a distinguished road
This is exactly what my car is doing, how would you fix it though?
OmeGa is offline   Reply With Quote
Old 07-09-2006, 05:20 AM   #5
supra90turbo
Perform a block test, compression test, and leakdown test.
You'll find the problem somewhere.
Pressure test your cooling system
Old 07-09-2006, 09:39 AM   #6
OmeGa
OmeGa's Avatar
http://www.cygnusx1.net/supra/techtip/bhgfaq.html
This helped me out a lot.
