Old 07-09-2006, 10:48 PM   #1
NYTRYDR
NYTRYDR is on a distinguished road
Cool body mouldings: questions and concerns
As many of you 87 88 and 89 owners probably know the body mouldings on our supras warp, rust, cause rust and are generally hard to keep looking like new . This is most definately due to their metal backing.
I've definately got some sick rust happening because of my mouldings and am considering filling them all in and putting on some sort of imitation moulding, or even scratching them altogether. Though, I've heard that in 90/91 they switched to an all plastic construction for the body mouldings. Can anyone confirm that ?
So my questions are as follow;
1. Do the 'new' plastic mouldings fit on 87/88/89s?
2. Are there any alternatives to paying outrageous prices for a set of used mouldings ?
3. How do you care for your mouldings ?
Info much appreciated.
NYTRYDR is offline   Reply With Quote
Old 07-09-2006, 11:22 PM   #2
supra90turbo
supra90turbo's Avatar
The side mouldings are there to protect from bumps and dings. They're level with other doors, so they do protect quite a bit.
86.5-88 had the steel-backed mouldings.
89-92 had the plastic mouldings.
yes, 89+ mouldings will go right in with no modifications IIRC. There is no difference in the sheetmetal, so, there is no difference in the mouldings mounting holes.
You WILL need 89+ taillights to finish the job as 86-88 taillights will not accept the new center piece, so you'll have new mouldings all the way to the rear, but the center will not be the same.
Not a big deal to someone like myself who prefers the 89+ 3-piece taillights.
Not to mention, all you have to do to install the taillights is drill 2 small holes and that's it.
Filling in the mouldings is not recommended if you want to avoid door dings, but if you like the smoothed out look, you need to weld in strips of sheetmetal to fill the void, then finish off with a skim of bondo. If you do it right, you won't even need the bondo.
Old 07-09-2006, 11:23 PM   #3
NYTRYDR
Great, do you have pics of your tail lights ?
Old 07-09-2006, 11:38 PM   #4
supra90turbo
not mine, but this is them.
Actually those are JDM tails. They're tinted a bit darker than USDM.
Old 07-10-2006, 04:54 AM   #5
newbsupra
newbsupra's Avatar
i have an 87 and mine look a bit darker.. and how much are these newer ones anyways. i just need them on the doors, but would they match?
Old 07-10-2006, 05:14 AM   #6
NYTRYDR
Those look pretty kickass. Anyone selling a set of 1990 mouldings and tail lights ?
