Old 07-11-2006, 04:09 AM   #1
liona
liona is on a distinguished road
Default '92 7MGTE- high and unstable idle
GreetingS to all!
Need help pls with HIGH and UNSTABLE idle. Idling RPM fluctuates up and down between 1400 to 1800. I sprayed the vacuum hoses connections with carb cleaner, and don't appear to have any vacuum leaks. Timing set at 12 deg BTDC.
I did notice a crack (which I temporarily tape wrapped) near the hose clamp on the big hose/tube connecting the turbo to the air cleaner . Could this be causing the erratic idle? If not, pls advise whatelse could be causing it.
THANKS MUCH IN ADVANCE FOR YOUR HELP!
liona is offline   Reply With Quote
Old 01-29-2007, 11:28 PM   #2
mattfurlani
mattfurlani is on a distinguished road
Originally Posted by liona
GreetingS to all!
any vacuum leak can be causing erradic idle.
any cracked hose is bad news. replace it regardless
Its broke, it could be anything, and cost of repairs will greatly exceed the value of the car
mattfurlani is offline   Reply With Quote
Old 01-31-2007, 05:07 AM   #3
Thumbs up Cleaning and testing tip
Don't use carb cleaner to check for leaks. It is too strong a chemical, and can cause problems with rubber hoses, electrical connections, and more, etc.
Use WD40, or the prefered,....brake cleaner spray.
Old 01-31-2007, 02:17 PM   #4
Staceman
Staceman is on a distinguished road
I had the same issue as you described. Turns out, the accordian hose to the turbo was split open. Very brittle. PO tried to silicone it, but no go. Only found out after removing it that it was split at the bottom. Couldn't see it otherwise. New hose at the dealer for $47, and she runs like a champ, and idle is great.
Staceman is offline   Reply With Quote
Old 01-31-2007, 04:14 PM   #5
mattfurlani
Any air coming in past that MAF sensor. The box right behind your air cleaner which has a black connector coming out of it is going to make your car idle funny. I have the same problem and i can't find it.
Propane is the best leak detector because it will make your car stop idling funny instantly. But its expensive and dangerous to use. its best to brake cleaner or something else
Old 01-31-2007, 11:56 PM   #6
rnoswal
rnoswal's Avatar
Wink Propane is Pro Way
Why would something that is expensive and dangerous be the best at detecting anything?!?!?!?! Like saying a stick of dynamite is the best way to put out a campfire, oh, it will do it, but what a mess.
Russ
Old 02-01-2007, 06:03 AM   #7
Wink Pros Use Propane
Russ
Actually, propane is the 'official' approved (EPA, & B.A.R.)gas to use for finding vacuum leaks. At the shop, we have a special adaptor (get from one of the tool trucks)on a bottle of 'camping' propane, with a hose to spray the gas(in short, small bursts) along intake manifold gaskets, and fittings, etc.
A leak will show up quickly.
I don't recommend this for home use or beginners.
Old 02-04-2007, 03:18 AM   #8
mattfurlani
yeha i mean that propane tanks can explode if your not careful about it. we use it in the shop to detect the leaks. its usually really good.
hesitation, high cold idle and poor gas mileage sd88supra MKIII Supra 14 02-06-2007 04:17 AM
