Old 07-18-2006, 11:48 PM   #1
Isphius
Isphius's Avatar
Default My brake lights are stuck on. wtf!
I drove home from work, and my brake lights work fine. I know this because the bottom cover of the third brake light is missing, and previous owner chopped a whole in the bottom of the light assembly, So my third brakelight reflects off of my sun screen thing for the windshield i have back there. So i know when the brake lights are on. I pull up at home. All is normal. I went to get my lunch cooler outa the trunk, So i would have noticed a light shining in my face. I get out and go in, And i know for sure my lights were off when i went inside. About 5 mins ago, My grandma tells me the lights are on on my car. And i ask the inside lights? and she says no, the ones in the back. So im like wtf, thinking she doesnt know what shes talking about, and i go out there and my brake lights are lit up. I started the car(charge the battery up) and i played with the brake pedal. No dice. I even drove around some small local roads to see if something happened, watching the third brake light the entire time(all 5 bulbs lit up BTW). So I just pulled the tail lights fuse, and theywent out and came in to write this. Im pretty sure its not a short, because when i took the fuse out. Faulty pedal switch mayber? I really need some ideas, because i have to drive to work at 5 am, and i definatley need my brakelights to work . Im about to look through the online tsrm, but any help here appreciated. Thanks
Old 07-18-2006, 11:59 PM   #2
theWeezL
theWeezL's Avatar
yeah I would bet a bad switch...although its wierd it would go bad working, instead of not working.
____________
Old 07-19-2006, 12:05 AM   #3
Isphius
Isphius's Avatar
Yes thats why i think it may be something else. Usually they do stop working at all. Im gona pull it out and clean it, if i can find it, It might just be stuck. Who knows? BTW weezl, i had a cool idea for your targa top brace...im gona post it on ure brace thread. Anyone else have some ideas on what to check out?
Old 07-19-2006, 12:32 AM   #4
Isphius
Isphius's Avatar
Great, I go out there with tools in hand and its raining. Of all the times. Its not even like little rain its moses 40 days at sea rain. Thanks earth and supra!
Old 07-19-2006, 01:41 AM   #5
go and adjust the switch so that the pedal is always resting on it when you aren't braking
Old 07-19-2006, 02:24 AM   #6
Isphius
Isphius's Avatar
Well its dark now so id have to look tommorow. Thanks thou! where is the switch located. I hope i dont get fired for going in late
Brake Lights zebrahabitz MKIII Supra 2 08-13-2009 06:29 AM
Brake Lights? bpalmer21 MKIV Supra 2 07-23-2006 04:15 AM
87 supra brake lights ministrytrav MKIII Supra 4 11-23-2005 08:53 PM
brake lights problem MWoz34 MKIII Supra 2 09-14-2005 03:08 AM
