Old 07-21-2006, 12:03 AM   #1
hbear1300
hbear1300 is on a distinguished road
Default JDM Automatic Transmission Problem-Please help!
Hi, I am replacing my original 88 Supra automatic transmission with a JDM replacement for the same year(s) 86-92. The shop that is doing the swap for me called today and said that the speedometer connection is on the wrong side of the rear of the transmission and that the connection cable/wire is not long enough to reach. Has anyone else had this problem and a solution? Can you just cut the speedometer cable wire and splice it to make it longer? Or can you remove the rear housing peice of the transmission and swap it with the original to have the correct speedometer connection? If so, do you have to swap the speedometer gears too? Here are pictures of what I am talking about. Any help is greatly appreciated!
hbear1300 is offline   Reply With Quote
1986 Turbo Automatic Transmission Rebuild? professorbob MKIII Supra 2 01-26-2012 01:06 AM
Automatic transmission strength pgoughary MKIII Supra 0 12-29-2006 06:48 PM
automatic transmission dblonka MKIII Supra 0 09-22-2006 03:02 AM
transmission problem URGENT HELP!!! landspeedxxx MKIII Supra 6 04-17-2006 06:13 PM
transmission problem lethalwithasupra Non-Generation Specific Questions 2 02-14-2006 05:28 AM
