Old 07-31-2006, 04:10 PM   #11
supra90turbo
supra90turbo's Avatar
supra90turbo is on a distinguished road
http://www.4cefed.com/conversion.html
supra90turbo is offline   Reply With Quote
Old 07-31-2006, 05:19 PM   #12
Dejvid1785
Dejvid1785 is on a distinguished road
So you stuck with the w-58? Mine also came with a LSD luckily but i wanna run somwhere around 400 horses and i know that tranny will not like that.
88 Targa: Exhaust, Headers, Intake
Dejvid1785 is offline   Reply With Quote
Old 08-01-2006, 01:27 AM   #13
gomezmk
gomezmk is on a distinguished road
I f you plan on running 400hp you have to go with the r-154 tranny. The engine cost me 1,000 dollars. when i got my engine it came with a cut wiring harness, turbo,accordian hose,fan and intake manifold including the throttle body. jdm throttle body's are different in that no linkage is involved, instead your cable goes straight on the throttle body but you got to make some kind of bracket to hold the cable.Also very very important, when you get the jdm engine, change out the oil pressure sensor. Japan does not read psi, it's something else. I left my on and when I turned the key on engine off, my oil gauge rose up all the way up and then it came down. what it did was it broke my oil gauge. And for the na tranny w-58, no mod was made, the 7mgte will perfectlly mate the na tranny problem free.The length of time it took me to do the swap was about 3 month because I bought most of my stuff on ebay.
gomezmk is offline   Reply With Quote
Old 08-01-2006, 08:24 AM   #14
Supra2NR
Supra2NR's Avatar
thank you for clearing that up
cuz im hurting with money already right now
knowing that i dont need to buy another tranny
gives me sum sort of relief
what about the ecu, did you get another one from a turbo?, and the afm?
what do those ones from a lexus looks like?
is it the same one found in turbo 7m's
Old 08-01-2006, 11:50 PM   #15
CzA
CzA is on a distinguished road
To remove the intercooler, do I have to take off the front bumper, and is there anythign else i have to take off to get at it?
Thnaks.
I believe you have to use the turbo ecu, i am not sure if thelexus one will work.
CzA is offline   Reply With Quote
Old 08-02-2006, 01:53 AM   #16
Supra2NR
Supra2NR's Avatar
one more
any good resources,
im looking to buy a 7mgte engine around 600
the guy that i was suppose to buy the engine from got arrested
so i have no acces to him
he was a drag racer/ drug dealer type of person
and how much will be r134 tranny anyways?
Old 08-02-2006, 03:22 AM   #17
tone loc
tone loc's Avatar
I have been lookin around and its hard to find the r-154 trans but i found a couple and the least was like $350 (it was in bad shape) and the most was like $600.
Old 08-02-2006, 05:03 AM   #18
Dejvid1785
I think the easiest way is to buy a donor car, you have everything you need.
Old 08-02-2006, 06:05 AM   #19
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
donor car
or
ecu
wiring harness
usdm throttle body
egr (if you have emissions in your state)
usdm oil pressure sender
turbo tacho, plug n play (look on ebay, for sale sections etc)
to make it easier get a wiring harness for your year (i.e. (86-88) yellow plug to yellow plug, or (89-89) (90-92) grey plug to grey plug) will be straight plug in then
ignitor
coils
pressure sensor
afm (7mgte)
use your box or auto trans
use your driveline
can't think of anything else
Pics of my build.
Do a diagnostic first!
85 Supra Swap (Help) Guillen_Don MKII Supra 2 03-01-2008 02:15 AM
89 Supra Turbo w/1JZ Swap Problems Donnies Foreign Car Non-Generation Specific Questions 1 02-02-2006 05:03 PM
