#11 |
7M POWAH! ;)
check your gounds
this is why the car won't go! the two earths on the intake manifold are the grounds for the ecu check your grounds!
Please use the forum to ask your questions as they will get replied to much faster than pming me ![]() Pics of my build. "Good girls are just bad girls that don't get caught" ![]() Do a diagnostic first! |
#12 |
There is a way to test your ecu by measuring its resistance, I dont know what part it will check out tho. But generally if the resistance of any electrical component is different than factory, Its a good idea to replace it. Look in the tsrm. And yes, Def check all your grounds. Bad ground = Bad stuff.
Yay the supra assistant is gone!!! WEEE!! |
#13 |
It was a blown fuse so to my EFI but now that it is fixed my car starts right up but it is still having trouble running. I know there is something messed up with my TPS because it idles at 500 rpm but i am still getting a rich fuel mixture which leads me to believe my Mass air Meter is dead too. I checked the codes again and got 51 and 31 I need to know if there is anything i should do before buying a new TPS and MAF.
#14 | |
![]() Quote:
#15 |
7M POWAH! ;)
code 31
Air Flow Meter Signal (7M-GE) Open circuit in VC signal or short circuit between VS and E2 when idle contacts are closed. (7M-GTE) Open or short circuit in air flow meter signal. Air flow meter circuit Air flow meter ECU http://cygnusx1.net/supra/library/TSRM/fi/FI_038.html code 51 Switch condition signal No "IDL" signal, "NSW" signal or "A/C" signal to ECU, during diagnosis check. Check to to make sure you were in Park or neutral when doing the diagnostic and also check to make sure a/c wasn't switched on when doing the diagnostic try another air flow meter and you haven't said if you have fixed your grounds
#16 |
jus listen to the girl she knows what shes talking about
jus fix the ground and if that doesnt work consider a licensed professional
http://www.myspace.com/supra_2nr ![]() Into Bikes now,, apparently the supra couldnt kill me, so my zx6 might lol |
#17 |
Well i would assume he now fixed the elctrical problem becasue the car starts, And is now trying to fix the bad running problem. But yes the ground wires are probably what caused the code 11 in the first place. I think it would be fine now that its giving him real codes.
#18 |
Yes the grounds are good now im just gunna replace the MAf And TPS and see what happens.
#19 |
7M POWAH! ;)
just do the afm (not maf on ours)
