I was just wondering i just bought a boost control and i was wondering what my stock turbo and injectors and ECU . What P.S.I can it run efficenitly??? PLZ Get back to me
somewhere around 6.8 psi i think thats about where it shows up on my stock boost guage
Guest
Posts: n/a
yer a stock supra does 6-7 pounds of boost, but they can efectivlely handle 11 or 12 until u hit fuel cut. I plan on boosting mine (with help from a few washers) to about 10 pounds when my new motor is installed.
10psi stocker turbo will be happy and no fuel cut problems
don't buy a fuel cut defender
if you've NEVER experienced fuel cut off before .. you will crap your pants the first time it happens to you .
#6 |
Guest
Posts: n/a
yea that fuel cut is a B----! i have a turbonetics turbo and hit it all the time..
#7 |
check this out its a must if your going above 12 psi. http://www.turbosmart.com.au/fuel_cut_defenders.htm
#8 |
don't waste ya money.. they won't work on our cars
our cars require Type K fuel cut defenders which only hks make i believe and if you want to put a fcd on you will need to ensure you have the fuel above fuel cut... a fcd clamps the signal from the afm to the ecu... the ecu from now on will never know above a certain amount of air how much is "really" going in therefore if you raise the boost from say 10 to 15.. the ecu won't know it and will not send the required fuel to go with it... then BOOM rebuild time make sure you have the fuel
#9 |
ok ok, thats cool just thought it would help
#10 |
good ya willing to find info for the members of this forum
![]() and now ya know what fcd we need :P
low boost psi, wtf | supradad86_5 | MKIII Supra | 4 | 02-09-2014 02:05 AM |
wont hold boost | Supraman | MKIII Supra | 12 | 04-19-2007 04:52 AM |
issue w/ boost spikes? i think? | NOTORIOUS VR | Non-Generation Specific Questions | 17 | 01-17-2007 08:35 PM |
installing manual boost controller 1989?? | hamburgler | MKIII Supra | 4 | 07-13-2005 12:55 PM |
No boost in neutral but boost in gear! | edgardo | MKIII Supra | 5 | 10-09-2004 04:01 AM |
