Old 07-31-2006, 05:25 AM   #1
gomezmk
gomezmk is on a distinguished road
Default fuel
I had a question about the areo fuel regulator kit. I know its adjustable but doe it react to boost pressure increase where the more boost is present, the more fuel pressure is given or does the regulator max fuel pressure is set at 0" vacuum. Also I got a 87 turbo supra and I raised boost to 10 psi, I got a walbro 255lph hot wired, will my car run lean or do I need a adjustable regulator.
gomezmk is offline   Reply With Quote
Fuel pump relay and pressure. carfanatic89 MKIII Supra 8 05-01-2008 06:39 PM
Fuel issues!! teedoff00 MKIII Supra 1 01-01-2008 05:09 AM
fuel pump mounting bracket GremlinMKIII MKIII Supra 4 09-06-2007 07:08 AM
Testing for bad ECU, &/or bad Fuel Pump elliotl MKIII Supra 0 08-21-2007 10:42 PM
Fuel Octane scruffboy Non-Generation Specific Questions 3 09-08-2006 06:49 PM
