Old 07-31-2006, 11:05 PM   #1
72charger
72charger is on a distinguished road
Default Newby questions...
High all. I am considering purchasing an 87 Supra non-turbo from a guy. It has a major coolant leak and he thinks it's the head gasket despite that there is no coolant mixing with the oil. I read on here that the coolant passage can simply leak into the combustion passage and just get burned away so maybe that's what is wrong. It also has a check engine light on. Not sure why, the car seems to run fine. I am a newb to Supras but not to cars nor to turbos. I am considering buying this car and replaceing the head gasket asap, and diagnosing the check engine light. Then I'm just gonna mess around with it until I have the money to do an overhaul under the hood. How much boost can I run in the stock NA motor? I plan to buy a relatively stock type supra turbo, intake manifold and full turbo exhaust. What else do I need to do it. I know the compression is higher on a non-turbo motor. What all would I need to do internally to the motor to run 15-20psi? I know it will need low compression forged pistons but what else?
Also, are there any motor rebuild walkthroughs or guides for a turbo application? Thanks for any help you can give!
72charger is offline   Reply With Quote
Old 07-31-2006, 11:07 PM   #2
72charger
Also, how much power can the stock tranny take before I start having problems? And how do I know which one I have? It is a 5 speed.
Old 07-31-2006, 11:13 PM   #3
AZN_Pride
AZN_Pride is on a distinguished road
Ide suggest the new engine. Sounds like theres a lot of problems. I am unsure about the PSI though. I know I can run 13PSI on my engine but I have upgraded rods and pistons and 550cc injectors and a larger fuel pump. Also I have the MKIV intercoole(dont think that has anything to do with it)
AZN_Pride is offline   Reply With Quote
Old 08-01-2006, 12:39 AM   #4
Isphius
Isphius's Avatar
The w58(you have) cant take a lot, But some more than the stock 205 ish that the na makes. If you convert to turbo be sure to get an r154 and they are good for some more power.
Old 08-01-2006, 04:08 AM   #5
sharkn
sharkn is on a distinguished road
can you fix the coolant issue and reset the ecu to see if the check light comes back on?
sharkn is offline   Reply With Quote
Old 08-01-2006, 11:01 AM   #6
72charger
Well if I buy it I think I'll probably run it NA until I actually have all of the parts I would need to turbo it. Something else I didn't think about until last night was oil lines to the turbo. I don't know what all it takes to do that. I imagine I'll end up having to find a turbo Supra in a junk yard and salvaging a bunch of turbo components off of it.
As far as the check engine light. I figured on reseting the ECU and checking it but are there any common causes for check engine lights in these cars?
Questions about the oem fuel system Magical Trevor MKIV FAQ 7 08-19-2007 04:40 PM
new here, few questions SoooopRa! MKIII Supra 6 08-29-2006 11:25 AM
newbie questions erik MKIII Supra 4 01-10-2006 11:37 AM
