Old 06-27-2008, 02:58 AM   #1
abhattan
abhattan's Avatar
abhattan is on a distinguished road
Usually that "buzzing" noise is the relay opening and closing extremely fast. That means that it is not getting the correct amount of voltage or current. It might be a little difficult, but check the voltage going into it on the coil part of the relay. If it's too low, that's your problem. But the car has to be running. I somewhat of a current draw in my car which is similar. My dome lights come on whenever it seems that the car has enough juice. The buzzer changes tones as the voltage increases as well. I probably have current draw somewhere, but it's not bothering me right now. Let me know what you come up with.
'91 Turbo Targa 5 Spd.
'87 Corolla GT-S 5 Spd
'91 Accord Daily Driver 5 Spd
Soon to be rebuilt (All to some extent)
abhattan is offline   Reply With Quote
Fuel pump relay and pressure. carfanatic89 MKIII Supra 8 05-01-2008 06:39 PM
MSD fuel pump? redmaro MKIII Supra 6 08-24-2007 04:09 PM
Testing for bad ECU, &/or bad Fuel Pump elliotl MKIII Supra 0 08-21-2007 10:42 PM
Fuel Pump Relay noise GremlinMKIII MKIII Supra 12 06-19-2007 08:27 AM
fuel pump relay Supra2NR MKIII Supra 4 05-18-2007 11:35 PM
