Old 08-03-2006, 12:15 AM   #1
newbsupra
newbsupra's Avatar
Default custom intake Q's
hey. i got around to making most of my custom intake, like Weezl did. i was just curious, the line that is connected to the bottom of the stock intake, does it have to? or can i just zip tie it to something? also, i am going to buy a Ractive air filter, $25.. and i dont have the adapter for it.. i was curious if there was a way to make something.. or will i have to buy one off ebay?
Old 08-03-2006, 05:19 PM   #2
theWeezL
theWeezL's Avatar
The line that comes off the accordian hose is part of the idle up circuit for when the car is at idle and you turn the wheels. It allows the engine to maintain proper idle speed when the PS pump is at max load (and therefore max drag on the engine).
Its not 100% needed to make the car run and does NOT affect how the PS system works. If there is a REALLY good reason why you cant, or dont want to hook it up, it wont hurt anything, but make sure you plug it all off.
The valve on my 89 has a broken nipple on it, and there is no way to connect a hose to it (without replacing it, which I just havent done yet) so I have mine plugged off for right now, and I dont notice it enough for it to be a problem.
____________
im looking for a custom intake manifold supravan Show n Tell 10 09-21-2008 04:32 AM
Custom Intake HeadofaHessian MKIII Supra 5 10-02-2006 04:29 AM
custom intake ?'s burton51m MKIII Supra 41 06-09-2006 05:33 PM
