Old 08-04-2006, 05:38 AM   #1
tone loc
tone loc's Avatar
Default i f**cked up big!!
I was trying to get to my spark plugs and so i was taking the air intake off and i got a couple bolts off and i put them aside. Then one of my friends walks in and he was in a rush to see my car and check it out for the first time. So then i put the bolts on really quick and i accidently put the wrong bolt in the wrong hole and the head of the bolt snapped off and now the screw is stuck in the intake (metal part) and none of the screw is sticking out. What should i do?? I hear there is a special tool for getting this kind of thing done. If there can someone tell me what its called and how to get a hold of it? Thanks
Old 08-04-2006, 08:13 AM   #2
Bill UK
AEM EMS
Bill UK's Avatar
See links for instructions, this will give you some idea what's involved.
http://www.newmantools.com/drillout/how1.htm
http://www.nextag.com/bolt-extractor/search-html
Old 08-05-2006, 03:17 AM   #3
marc
take a drill with a very sharp tip...drill a hole straight through the middle of the screw. imake suer the drill bit is just big enuff to fit...and then jut pull the threads out with pliars once the screw has been drilled thru.
nothing but the best
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
4 washers on the wastegate
highflow cat
short shifter
many more upgrades soon
Old 08-05-2006, 04:14 AM   #4
tone loc
tone loc's Avatar
ill try using a drill bit tommorow and ill let you know how it goes.
Old 08-05-2006, 04:29 AM   #5
theWeezL
theWeezL's Avatar
you need to be very careful when doing this. The bolt will be quite hard and unless it broke off pretty flat, its going to be hard to get a drill started going in straight. It will want to slip off the side and get into the aluminum of the manifold. Once you do that it becomes nearly impossible to get the broken bolt out.
Take your time, make sure you have a good sharp drill bit and stop if you think your messing it up.
____________
Old 08-07-2006, 04:32 AM   #6
mrnickleye
mrnickleye's Avatar
I ALWAYS use a very hard and pointy punch to make a dimple in the place where I want to drill. That way the drill bit won't wonder off course.
You may want to drill a pilot hole, then go up a couple of sizes with the second drill.
Old 08-07-2006, 05:16 AM   #7
tone loc
tone loc's Avatar
ya thats what i was planning on doing i just got to find my drill.
Old 08-07-2006, 05:58 PM   #8
Bill UK
AEM EMS
Bill UK's Avatar
I've never tried this but I see no reason why it wouldn’t work., a conventional right-handed drill could screw the broken stud or screw further in. If you ground the shank off a high speed steel drill and re sharpened the now new cutting end and put the drill in reverse to drill the stud out, you may find the stud would start to unscrew on its own. I know you can buy left-handed HSS drills but its probably more convenient to make one.
Old 08-08-2006, 10:41 AM   #9
Bill UK
AEM EMS
Bill UK's Avatar
Just found this.
http://www.mytoolstore.com/hanson/hanson.html
Name:	LEFT HANDED DRILL BIT 2.jpg
Old 08-08-2006, 02:16 PM   #10
Isphius
Isphius's Avatar
If all else fails, I have an extra n/a manifold sitting in my garage that ill sell for 10$. lol.
