Old 05-19-2005, 10:19 PM   #11
Frank
Frank is on a distinguished road
Thanks for the info. Yes, I don't drive it much. I bought it new in 1988 and only have 118,000kms on it. It's never been in the snow and has only seen rain 5 or 6 times. It's been really pampered which is why it's all the more frustrating to have to deal with these type of issues.
BTW... the car was almost 2 years past warranty when the first HG failed and Toyota covered it under "goodwill".
Thanks again.
Frank is offline   Reply With Quote
Old 06-09-2005, 04:30 PM   #12
ddmcse
ddmcse's Avatar
BHG
head torque is one issue with the inline six of that era but another major flaw is the bolt design
there are only 4 bolts around each cylinder and if you look at most other engines you'll see 5 bolts around the cylinder .
less bolts means more distance between bolts and less ability to keep pressure constant between the bolts
bolts should be replaced with studs
just replacing the head gasket with a metal one is not gonna cure the problem you need to surface the head and block to finer than even a machine can smooth it out
have a look at some of my bhg shots
http://www.ddmcse.com/turbo/bhg_2003.htm
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 06-09-2005, 04:31 PM   #13
ddmcse
ddmcse's Avatar
the same engine in the same year 4 runner has been factory recalled but they didn't do this for the supra
My Supra KiXGaS
Replacing the headgasket burton51m Show n Tell 4 07-12-2010 04:47 AM
Type of Headgasket justin1642 MKIII Supra 1 01-29-2007 11:59 PM
Best Metal Headgasket papaleach MKIII Supra 1 11-19-2006 05:28 PM
How to do a HeadGasket Job SupraSaver87 Non-Generation Specific Questions 3 09-08-2006 02:22 PM
Headgasket question? joebuffalo Non-Generation Specific Questions 4 10-21-2005 01:46 PM
