Old 08-07-2006, 12:44 PM   #1
grygst76
grygst76 is on a distinguished road
Default will the supra run with no AFM??
I was having an issue with my AFM, now the car has died and will not start again, will unplugging my AFM make the car at least limp?? Or will it not run at all??
grygst76 is offline   Reply With Quote
Old 08-07-2006, 04:10 PM   #2
Supra2NR
Supra2NR's Avatar
hell yea it can run without the afm
with the help of a stand-alone fuel management system
but right now taking that thing off would cost you more problems and jus make your situation so much worse
Old 08-07-2006, 06:19 PM   #3
grygst76
does the lexus afm work with the turbo supra?? is the sensor the same???
Old 08-07-2006, 08:01 PM   #4
supra_91
supra_91's Avatar
yes it will work but you have to get bigger injectors to compensate for the increase in air supply
Old 08-07-2006, 10:12 PM   #5
grygst76
so how will it run?? I'm only going to use the electronics anyways
Old 08-08-2006, 05:07 AM   #6
Supra2NR
Supra2NR's Avatar
your still gonna need bigger injectors since the air-flow is going to change cuz of the new afm
but it can work
Old 08-09-2006, 03:30 AM   #7
White87Turbo
White87Turbo is on a distinguished road
I have a AFM of a 87 Turbo that is in perfect shape. Ill sell it to you for 120
White87Turbo is offline   Reply With Quote
Old 08-09-2006, 04:44 AM   #8
tone loc
tone loc's Avatar
whats afm?
Old 08-09-2006, 05:03 AM   #9
marc
air flow meter..its the thing that is attached to ur air filter right after the filter itself. it is in sumthing that looks liek a small metal box attached to ur intake pipe.
nothing but the best
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
4 washers on the wastegate
highflow cat
short shifter
many more upgrades soon
Old 08-09-2006, 03:16 PM   #10
grygst76
I found one at a boneyard near my house off a lexus ls400 1992, Im going to just use the electronics... Thanks for all your help guys...
