Old 08-11-2006, 04:06 AM   #1
Supra2NR
Supra2NR's Avatar
Default more
more interiors
one up top if the lower rear quarter panel, it goes right after the door
the one on the bottom is the middle part of the trunk
and i noticed one thing in thr trunk area
whats this it has a sensor under it connected to something could some enlighten me
more would come soon
this interior wasnt as easy to paint as i tought it would
i guessing its gonna cost me around 100 dollars when it all said and done
still cheaper than getting new ones tho
Old 08-11-2006, 05:03 AM   #2
damdog05
damdog05's Avatar
damdog05 is on a distinguished road
it looks like something to do with your suspension. do you have TEMS? it looks like the cover for tems might bolt to that. just my $.02 tho. could be wrong
My cars:
85 Trans Am- Ehhh- Gone
83 Rx7- Much Better- Gone
86.5 Supra- Love- Not Gone
damdog05 is offline   Reply With Quote
Old 08-11-2006, 04:46 PM   #3
supra90turbo
supra90turbo's Avatar
supra90turbo is on a distinguished road
white rice!
that's the fuel pump access panel. You can't pull the sender out through that hole, but that allows you to unhook the electrical connections for when you pull the tank down.
supra90turbo is offline   Reply With Quote
Old 08-11-2006, 06:14 PM   #4
rnoswal
rnoswal's Avatar
Actually I think it is just the access for the fuel level sender unit. There are no hoses going to it. I think you have to drop the tank to get to the access for the fuel pump. I am pretty sure but not positive about this.
Russ
Old 08-11-2006, 07:33 PM   #5
damdog05
damdog05's Avatar
what was white rice for? if it was directed at me youve got a problem. i was just trying to help as best i could. so what if i was wrong. if it wasnt at me, ok then.
My cars:
Old 08-11-2006, 10:01 PM   #6
Isphius
Isphius's Avatar
Why would he be saying white rice at you? he was talking about the car being white inside and out... But yah anyway that just goes to the fuel sender/pump wires. You need to drop the tank to get either of those pieces out thou. nice job on the paint supra2nr
Old 08-13-2006, 11:11 AM   #7
f00g00
Remove the screws on the botom of the panel should be about 5 or so. Take the screw out of the cup under the inner door handle. Remove the two caps on the door panel that you grab to close the door and loosen the two screws there ,and there is one or two fasteners that you have to pop out towards the back then lift from the back up to remove the molding where it fits over the door and mates to the window.
You will have two connectors also, the interior light on the aft bottom and the one that plugs into the multi switch for the windows.
Old 08-14-2006, 04:40 AM   #8
damdog05
damdog05's Avatar
theres a sticky here in the mk3 section that will help...titled "dashboard removal"
My cars:
Old 08-14-2006, 06:35 PM   #9
Supra2NR
Supra2NR's Avatar
thats a lot, idk
i guess ill have to see about that first, cuz the screws are startign to confuse me
plus i havent got sleep in 2 days
Old 08-16-2006, 05:20 PM   #10
Supra2NR
Supra2NR's Avatar
Default i did sum more
i took out some out of the front
i took the center console out
the door sills
the glove box
but when i was taking the
center panel out look at what i found
somebody was definitely blazin up in this ride
the center console, from the ugly maroon to this
made it a little more mine
it was to simple
so a little personalization never hurted anybody
the glove box
i was bored and i thought it was gonna b funny
even if it isnt, it makes the car more mine
so no hatin
i also painted the dead pedal
get it "dead pedal"
oh shut up, it was funny when i thought about it lol
