Old 08-13-2006, 05:52 PM   #1
tone loc
tone loc's Avatar
Default coolant plugs suck balls
i got an 87 supra and im trying to change the coolant and i cant find the plugs. the tsrm isnt realy helping because there are so many things under there. please help. thanks.
Old 08-13-2006, 06:57 PM   #2
Bill UK
AEM EMS
Bill UK's Avatar
Drain plug for block: under exhaust manifold at the rear (see photo) Drain tap for radiator: bottom right under radiator, you mentioned a small rubber pipe sticking out of the bottom of your rad in previous post, well this is where the tap is.
Old 08-13-2006, 08:05 PM   #3
tone loc
tone loc's Avatar
i so i take that thing off or what do i do?
Old 08-13-2006, 09:26 PM   #4
Bill UK
AEM EMS
Bill UK's Avatar
The rubber hose is attached to a drain tap, turn the tap to drain the radiator also remove the rad cap.
Old 08-13-2006, 09:29 PM   #5
Bill UK
AEM EMS
Bill UK's Avatar
To drain the block remove the drain plug (in photo) completely.
Heater Union (Coolant Leak) slader99 MKIII Supra 11 12-28-2009 12:29 AM
Funky engine coolant issue shirkinator Non-Generation Specific Questions 1 06-22-2009 08:37 AM
coolant on top of piston sevenmgte MKIII Supra 8 05-02-2008 02:34 AM
Coolant leak issues D_Train MKIII Supra 1 03-15-2007 04:30 AM
1986.5 with blown Head Gasket - Removing Spark Plugs unkymurch Non-Generation Specific Questions 10 03-02-2007 06:48 PM
