Old 08-15-2006, 02:14 AM   #1
tone loc
tone loc's Avatar
Default tsrm lies
i went to change my trans fluid. the tsrm says to put 1.7 qts back in but when i drained the old fluid it measured to be a little over 2 qts. so i put in like 2 1/4 qts in and its still low. i ran out of time so i didnt put anymore ill do it tommorow. I just want to know if im doing something wrong?
Old 08-15-2006, 02:20 AM   #2
kwnate
Did you check the level with the trans being warmed up and in neutral?
Nate
Old 08-15-2006, 02:24 AM   #3
tone loc
tone loc's Avatar
i checked it while it was warmed up and i have a automatic so i didnt put it in neutral. before i checked i went through all the gears and it still was low.
Old 08-15-2006, 02:29 AM   #4
kwnate
In park, warmed up with the engine running?
Nate
Old 08-15-2006, 03:22 AM   #5
tone loc
tone loc's Avatar
yes thats right
Old 08-15-2006, 06:18 AM   #6
It actually will take about 2 1/2 qts. Not much out is it??? That why the best way is to go get it done by a shop that has a machine to do it.
Or look in the FAQs section for the easy traanny oil change.
Old 08-15-2006, 04:02 PM   #7
tone loc
tone loc's Avatar
how much does it usally cost to get it done at a shop? if its more than $10 no thanks ill do it myself.
Old 08-15-2006, 10:08 PM   #8
supra_91
supra_91's Avatar
i hate to break it to you but it will cost more than $10
Old 08-17-2006, 05:59 AM   #9
At my shop its $140.
Others charge less, like the big chain shops, Pepboys, etc.
I have been told by more than one customer how it was done "last time" on their car at the quickie lube place.
They stuck a tube down the dip stick hole and sucked out about 2-3 qts, and then topped it up. They paid $80 for that "trans service".
We actually use a machine and a flushing chemical, and it replaces ALL of the fluid with new.
Old 08-17-2006, 08:27 AM   #10
f00g00
The oil in the torque converter usually hold alot of fluid. More than a gallon I would guess.
Printable MK3 TSRM guide? trevor217 Non-Generation Specific Questions 1 06-19-2008 09:28 PM
TSRM for 1985 Supra mowvideo MKII Supra 1 11-19-2007 07:14 AM
TSRM not working mrnickleye Non-Generation Specific Questions 18 09-11-2006 03:50 AM
TSRM in PDF format ToyoSupraGuy MKIII Supra 4 05-20-2006 04:13 PM
I found a 1986 TSRM and factory service manual Kristamarie MKIII Supra 0 10-26-2005 04:31 PM
