Old 08-17-2006, 01:11 AM   #1
adamh88
adamh88 is on a distinguished road
Default high idle
So the other day I was leaving to a friend's house and I started my car and as always it idles crappy for a few seconds. So I rev it a little to get the idle up so i can go and oh it went up to about 2500 rpm and would not come down so i pop my hood and check for stuck linkage or anything like that and nothing. So I turned it off and the right back on and it was fine. It lasted aout 2 days and then started doing the same thing. so today I checked out my vacuum lines and replaced a few and fixed another and it still did the same thing. So i got irritated at it and floored it while i was starting and it idles fine so to test it i turned it off and started normally again and it was back high. I did the same thing and it seems to work fine if its floored when i start it (which i know isnt good for it) anyone know what this might be and how to fix it??? please help
adamh88 is offline   Reply With Quote
Old 08-17-2006, 03:49 AM   #2
burton51m
burton51m's Avatar
that happens to mine when its really hot and i let it cool down and start it again. when that happens i notice the oil pressure is very low. i rev it, watch the oil needle go up , and it is fine.
i dont know if yours and mine rough idle for a few seconds for the same reason or not but i thought i would tell you.
Old 08-17-2006, 05:15 PM   #3
jetscott
jetscott is on a distinguished road
ive had the same thing happen on a few different cars and its always been the same thing, TPS sensor. replace it and it should be fine. the reason it runs okay when you floor it is that the computer overrides the sensor at wot and dumps the full amount of fuel
Jetscott
jetscott is offline   Reply With Quote
Old 08-17-2006, 08:36 PM   #4
marc
its ur tps (throttle position sensor) sme thing happened to my borthers mustang, u ca adjust a scre to temporarily fix it, but just get a new tps.
nothing but the best
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
4 washers on the wastegate
highflow cat
short shifter
many more upgrades soon
high idle 3.0trd MKIII Supra 4 04-27-2008 03:37 PM
annoying high pitch squeal at idle oowee623 MKIII Supra 2 06-04-2007 03:02 AM
'92 7MGTE- high and unstable idle liona MKIII Supra 7 02-04-2007 03:18 AM
High idle nickvash0104 MKIII Supra 21 07-13-2006 05:14 AM
