Old 08-19-2006, 06:05 AM   #1
h8z2luze
h8z2luze's Avatar
Default Got Codes?
I got 3 codes in my 89 n/t supra, 24 - Intake Air Tempature Sensor Signal 41 - Throttle Position Sensor Signal and 52 - Knock Sensor Signal. What do you think of the codes? TIA.
Old 08-19-2006, 12:40 PM   #2
f00g00
You can read them all from the puter to the component connector to verity wires are fine. The tps and inlet temp have different readings in different conditions. I use my haynes manual to check mine. Knock sensor has a shielded wire that if shorted could cause a problem, just check all connections first though, last time I had some codes the TPS plug was hanging on half way.
on the pics the THA-E2 is you inlet air temp reading.
ID:	461   Click image for larger version
ID:	462   Click image for larger version
Old 08-19-2006, 05:53 PM   #3
h8z2luze
h8z2luze's Avatar
Cool thanks, I will check that out. I know the connections are good thats the first thing I checked.
Old 08-19-2006, 07:46 PM   #4
Are you having running problems???
If not, then I would clear the codes and drive it awhile, then check for codes again.
Old 08-20-2006, 04:50 AM   #5
h8z2luze
h8z2luze's Avatar
Yea, it idles like crap. Up and down up and down and when I come to a stop it usually dies unless I keep it going.
Old 08-20-2006, 06:47 AM   #6
Default Main Cause Is ????
This poor idle thing seems to happen to alot of supras. There must be some "usual" cause. I certainly have read a lot of complaints like this.
Old 08-20-2006, 11:54 PM   #7
h8z2luze
h8z2luze's Avatar
I cleared the codes then drove it around the block and got one code 52 - Knock sensor signal. I did have a couple loose bolts on the intake but they are all tight now and it didnt make a diffrence.
Old 08-21-2006, 12:10 AM   #8
damdog05
damdog05's Avatar
if someone could direct me as to the location of the knock sensor, and the anything related to it, i also have a code 52. and while i could search harder to find it, i havent found it yet. thanks
My cars:
85 Trans Am- Ehhh- Gone
83 Rx7- Much Better- Gone
86.5 Supra- Love- Not Gone
Old 08-21-2006, 01:13 AM   #9
h8z2luze
h8z2luze's Avatar
I was also wondering that. I remeber that I unplugged the TPS and the intake temp sensor and plugged them back in while the car was runing wich would explain those codes. But the knock sensor code is still there. I am wondering if air getting in between the air flow sensor and the intake inlet would make it idle like crap cause someone put a PVC pipe where there looks to be a canister of some kind on your guys' cars. lol. I tist it and the engine speeds up so I know its leaking. If I just got a aluminum pipe with silicone fittings that wont leak would that work??? TIA.
Old 08-21-2006, 06:34 AM   #10
Isphius
Isphius's Avatar
That canister is some kind of muffler or something. Its pretty pointless. I actually eliminated mine by getting PVC and shaving down the end to fit in the original adapter, And then i used a 3" rubber coupler on the AFM end. And yes, A vaccum leak from the intake hose will cause bad idle, bad gas mileage, And a weird hesitation or shaking when you start off in gear sometimes. Check that out. But since your computer is putting out codes, something is wrong with the tps most likely.
Error Codes 42 and 43 Getphazed MKIII Supra 6 09-14-2008 10:32 PM
Codes 25,26,51! justin1642 MKIII Supra 11 08-30-2007 08:08 PM
codes 22 24 31 kidthunder650 MKIII Supra 16 04-12-2007 11:54 PM
fault codes on a newly re-headed supra lethalwithasupra Non-Generation Specific Questions 5 09-28-2005 08:22 AM
diagnostic codes Alberto O. MKIII Supra 5 07-29-2005 12:50 PM
