Old 08-23-2006, 03:00 AM   #1
jfunez
jfunez's Avatar
sounds cool, but this may be out of the subject.
I hear a lot of guys talk about some shims somewhere on the head, the thing is when I dismantled my 7mgte head I found nothing that look like shims on the head or the camshaft.
Am I missing something ?
By the way, I'm still in the process of doing the metal headgasket...I symply ran out of funds.
so far I had the hed machined, cleaned and tested, ARP studs,some of the gaskets but still lacking the 1.4 mm Cometic metal head gasket and turbo gaskets.
Name:	machinned head online.jpg
ID:	470   Click image for larger version
Name:	machinned head online 2.jpg
ID:	471   Click image for larger version
Name:	valve cover painted.jpg
ID:	472   Click image for larger version
Name:	valve cover painted 2.jpg
ID:	473   Click image for larger version
Old 08-23-2006, 08:00 PM   #2
Bill UK
AEM EMS
Bill UK's Avatar
The only shims I know of are used to adjust the valves,see links
http://www.cygnusx1.net/supra/library/TSRM/em/EM_09.html
http://www.cygnusx1.net/supra/library/TSRM/em/EM_41.html
Old 08-24-2006, 02:38 AM   #3
jfunez
jfunez's Avatar
thanks alot bill ... that cleared my doubts greatly...
Old 08-24-2006, 01:40 PM   #4
ddmcse
ddmcse's Avatar
Cool
see the lines left by the milling machine ?
i removed those lines by hand, using a lapping tool
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 08-24-2006, 02:44 PM   #5
Bill UK
AEM EMS
Bill UK's Avatar
How much did you skim off your head ? looking at your photo there seems to have been a lot of material removed. This is the photo of my head straight from the block.
Old 08-24-2006, 09:00 PM   #6
jfunez
jfunez's Avatar
cant remember but it was a bit, that's why the machinist recomended me to get a 1.4 or a 1.5 mm head gasket also I ot in touch with a company that sell the cometic headgasket and told them how much it had been taken off of the head and he figured the same. It could of posibly been 20 thousands or something like that..
N20 and HeAd WoRk Supra_87_mk3 Non-Generation Specific Questions 4 05-25-2007 03:09 PM
Head and turbo... Reeves MKIII Supra 8 05-18-2006 02:40 AM
