Old 08-22-2006, 03:32 AM   #1
Dejvid1785
Dejvid1785 is on a distinguished road
Default Air Conditioner????
I did my head gasket on my 88 non-turbo and my ac worked before it was just blowing out not so cold air, in other words it was alright. When i put everything back together it doesn't work the ac compressor is not kickin in, i know this because when the car is on and i turn it on there is no power surge and there is no cold air duhhhh. Does anybody know what this could be? Could the ac compressor die like that instantly?
88 Targa: Exhaust, Headers, Intake
Dejvid1785 is offline   Reply With Quote
Old 08-23-2006, 05:17 AM   #2
You may have not hooked the power back up, or a ground wire. have a friend that knows about a/c to help you. These cars are about the same as all of the 80's & 90's.
You friend may want to see the TSRM on a/c wiring, so go ahead and look it up here.
http://www.cygnusx1.net/supra/library/TSRM/
Old 08-24-2006, 03:42 AM   #3
Dejvid1785
Where are the power wires located? I see a ground wire on top.
Old 08-29-2006, 09:14 AM   #4
f00g00
Default Ground on top?
The wire on top is the power wire, the clutch uses case ground for the ground.
Quetion about Air Conditioner whowouldfigga MKIII Supra 22 05-30-2008 01:09 AM
