Old 08-22-2006, 04:59 AM   #1
Luvs2slide
Luvs2slide is on a distinguished road
Question Oil Pressure...Mechanical or Electrical???
What kind of Oil Pressure guages does everyone use? Mechanical or Electrical? I'm leaning more towards the electrical just because I don't want to worry about a leak in the cabin. Also where is the best place to mount the sender unit? Will it fit in the stock senders location? Or would it be better to make a tap and drill out a new hole in the block? Thanks
Luvs2slide is offline   Reply With Quote
Old 08-22-2006, 04:19 PM   #2
supra90turbo
supra90turbo's Avatar
supra90turbo is on a distinguished road
Electric. You don't want 200*+ oil hitting you in the face do you?
supra90turbo is offline   Reply With Quote
Old 08-22-2006, 06:08 PM   #3
Bill UK
AEM EMS
Bill UK's Avatar
You may find this site useful http://hp.autometer.com/homepage/homepage.html
they have PDF files for fitting instructions as well, before you ask mine are air/fuel and vac/boost.
Old 08-22-2006, 08:30 PM   #4
ravenmaster
ravenmaster's Avatar
Location: Being not duly informed, I refuse to answer with any degree of accuracy for fear of prevaricating
ravenmaster is on a distinguished road
Nice guages
ravenmaster is offline   Reply With Quote
Old 08-22-2006, 09:04 PM   #5
tone loc
tone loc's Avatar
what is the oil pressure supposed to be at while your driving?
Old 08-23-2006, 12:42 AM   #6
Isphius
Isphius's Avatar
40ish or below is normal. Below 20 and your bearings are going bad and more than that and many things could be wrong, Like a blockage or something. It should stay around 40 or below tho.
7MGE oil pressure Arne (Denmark) MKIII Supra 14 07-31-2009 10:07 PM
Oil Pressure Sender!? spudz29212MKIII MKIII Supra 8 05-06-2008 01:41 PM
Fuel pump relay and pressure. carfanatic89 MKIII Supra 8 05-01-2008 06:39 PM
Tire pressure? dannydavi Non-Generation Specific Questions 11 08-16-2007 06:03 AM
oil pressure johnkarl MKIII Supra 2 11-05-2006 02:11 PM
