What kind of Oil Pressure guages does everyone use? Mechanical or Electrical? I'm leaning more towards the electrical just because I don't want to worry about a leak in the cabin. Also where is the best place to mount the sender unit? Will it fit in the stock senders location? Or would it be better to make a tap and drill out a new hole in the block? Thanks
Electric. You don't want 200*+ oil hitting you in the face do you?
AEM EMS
You may find this site useful http://hp.autometer.com/homepage/homepage.html
they have PDF files for fitting instructions as well, before you ask mine are air/fuel and vac/boost. ![]() |
Nice guages
what is the oil pressure supposed to be at while your driving?
#6 |
40ish or below is normal. Below 20 and your bearings are going bad and more than that and many things could be wrong, Like a blockage or something. It should stay around 40 or below tho.
Yay the supra assistant is gone!!! WEEE!! |
7MGE oil pressure | Arne (Denmark) | MKIII Supra | 14 | 07-31-2009 10:07 PM |
Oil Pressure Sender!? | spudz29212MKIII | MKIII Supra | 8 | 05-06-2008 01:41 PM |
Fuel pump relay and pressure. | carfanatic89 | MKIII Supra | 8 | 05-01-2008 06:39 PM |
Tire pressure? | dannydavi | Non-Generation Specific Questions | 11 | 08-16-2007 06:03 AM |
oil pressure | johnkarl | MKIII Supra | 2 | 11-05-2006 02:11 PM |
