Old 08-25-2006, 03:43 AM   #11
h8z2luze
h8z2luze's Avatar
h8z2luze is on a distinguished road
I have LOW gears lol. When im at 70 im at about 3200 or 3500
1989 Supra 7MGE MK3 5-speed project...
http://www.cardomain.com/ride/2385505
h8z2luze is offline   Reply With Quote
Old 08-25-2006, 04:43 AM   #12
damdog05
damdog05's Avatar
damdog05 is on a distinguished road
could someone explain this too me. why, in the same gear and at the same speed, do "low" gears have higher rpms, and "high" gears have lower rpms?
My cars:
85 Trans Am- Ehhh- Gone
83 Rx7- Much Better- Gone
86.5 Supra- Love- Not Gone
damdog05 is offline   Reply With Quote
Old 08-25-2006, 06:55 AM   #13
h8z2luze
h8z2luze's Avatar
low gears have a small actual gears so it doest take as many rpms to turn it enough to spin the other gear. The high gear has a larger actual gear so it takes more rpm to get it around. I hope this makes sense im really tired. And someone correct me if im wrong. lol.
Old 08-25-2006, 07:54 AM   #14
suprasforlife
suprasforlife is on a distinguished road
Originally Posted by grygst76
at 70 I am at 2100 rpms in 5th. 75 I think 2850
I've got 3.9 gears in mine and at 75 I'm at 2850 there about so I'd say you got 3.9 gears.
suprasforlife is offline   Reply With Quote
Old 08-25-2006, 08:08 AM   #15
suprasforlife
What h8z2luze said is close, the size of the gear is not that different, but the size of the teeth on the gear is. Smaller teeth means more of them and larger ones means less of them. For example, 4.11 gears have 37 teeth on the ring gear and 9 teeth on the pinion gear, so in short the driveline of the car must turn 4.11 times to turn the wheels all the way around once. You get your gear ratio by taking the number of teeth on the ring gear divided by the number of teeth on the pinion gear, 37/9=4.1111111111111. So if you have like 2.83 gears your driveline only has to turn 2.83 times to make the wheels turn all the way around once, thus giving you lower rpm. Hope this answers your question.
Old 08-25-2006, 08:11 AM   #16
Supra2NR
Supra2NR's Avatar
maybe i can help
lower gears have small circumferences that allows them to do a complete 360
faster
while the higher gears have a bigger circumference, hence a longer rotation
bcuz the lower gears needs to rotate more to produce the same amount of power as the higher gear does
the higher gears puts out enough power so it does not need to rotate any faster
rpm = rotation per minute
im not making you sound stupid,
but look at it this way
you got the lower gears as a , small guy , really quick but no muscle
then you got the higher gears, big guy, muscular, but no speed
to push a 3600 lbs object
the smaller guy needs to work more harder than the muscular guy
i did my best to explain that, may not have the proper terms but, i think it works,
if not, oh well i gave it my best shot
hopefully it helps
Old 08-26-2006, 01:50 AM   #17
h8z2luze
h8z2luze's Avatar
I found mine, its G285
Old 08-26-2006, 07:05 PM   #18
h8z2luze
h8z2luze's Avatar
So would that mean that the rearend has 4.30 gears like 4.11's? Cause that would be really low.
Old 08-27-2006, 02:22 AM   #19
suprasforlife
Yup, you got some the lowest ones there is, great for in town and racing, shitty for the highway.
Old 08-30-2006, 02:32 AM   #20
damdog05
damdog05's Avatar
thanks for the explination. ive got it all worked out in my head now.
My cars:
MK4 Rearend Gearing? Sub-Zero MKIV Supra 0 10-12-2008 12:01 AM
