Old 08-29-2006, 01:29 AM   #1
thetrueaint
thetrueaint is on a distinguished road
Default Warning light question
I have a 1990 supra turbo. In the gauge cluster there is a warning light on that looks almost like a radiator. My levels are fine but the light goes on everytime I make a left hand turn. The light flashes a few time then stays on. Unfortunantly I do not have the origional owners manual and the after market repair manual I purchased does not explain what this warning light means.
Hopefully you can put an end to my confusion.
Thank You
thetrueaint is offline   Reply With Quote
Old 08-29-2006, 02:36 AM   #2
Supra2NR
Supra2NR's Avatar
that is what everybody here call a birdcage
that means your coolant reservoir (the one by the front bumper)
is a little low
the light shows up everytime you make a turn bcuz
when you take a turn the coolant moves around exposes the sensor
and makes it think that its out
so jus put sum more coolant in there and you should be good
Old 08-29-2006, 02:59 AM   #3
thetrueaint
Default Thanks a lot man
You saved me from having to buy some random user manual on amazon or something.
Thanks Again
Chris
Old 08-29-2006, 03:31 AM   #4
Dejvid1785
Dejvid1785 is on a distinguished road
The force of you taking a corner forces all the liquids or whatever is left to shift to one side causing the gauge to read it as low.
88 Targa: Exhaust, Headers, Intake
Dejvid1785 is offline   Reply With Quote
Old 08-29-2006, 06:07 AM   #5
Supra2NR
Supra2NR's Avatar
its a common problem for every new supra owner
because the picture on the dash is a guesswork as it is already
so no problem, glad to help
and one more thing
this is the holy bible for supra owners
http://www.cygnusx1.net/supra/library/TSRM/
Check Engine Light & Warning light on Chomper MKIV FAQ 19 02-11-2011 12:51 PM
Engine light and warning light on. Chomper MKIV Supra 11 07-18-2008 11:44 AM
Warning light question scruffboy Non-Generation Specific Questions 4 06-11-2007 11:16 PM
battery warning light / tail lamp failure warning light MattJ MKIII Supra 5 02-06-2006 07:22 PM
1987 Supra Warning light question Supraman4 MKIII Supra 3 10-17-2005 07:58 PM
