I have a 1990 supra turbo. In the gauge cluster there is a warning light on that looks almost like a radiator. My levels are fine but the light goes on everytime I make a left hand turn. The light flashes a few time then stays on. Unfortunantly I do not have the origional owners manual and the after market repair manual I purchased does not explain what this warning light means.
Hopefully you can put an end to my confusion. Thank You |
that is what everybody here call a birdcage
that means your coolant reservoir (the one by the front bumper) is a little low the light shows up everytime you make a turn bcuz when you take a turn the coolant moves around exposes the sensor and makes it think that its out so jus put sum more coolant in there and you should be good
You saved me from having to buy some random user manual on amazon or something.
Thanks Again Chris |
The force of you taking a corner forces all the liquids or whatever is left to shift to one side causing the gauge to read it as low.
88 Targa: Exhaust, Headers, Intake |
#5 | |
![]() Quote:
because the picture on the dash is a guesswork as it is already so no problem, glad to help and one more thing this is the holy bible for supra owners http://www.cygnusx1.net/supra/library/TSRM/
Check Engine Light & Warning light on | Chomper | MKIV FAQ | 19 | 02-11-2011 12:51 PM |
Engine light and warning light on. | Chomper | MKIV Supra | 11 | 07-18-2008 11:44 AM |
Warning light question | scruffboy | Non-Generation Specific Questions | 4 | 06-11-2007 11:16 PM |
battery warning light / tail lamp failure warning light | MattJ | MKIII Supra | 5 | 02-06-2006 07:22 PM |
1987 Supra Warning light question | Supraman4 | MKIII Supra | 3 | 10-17-2005 07:58 PM |
