right side lights not working!
my right headlight and tailight arent working! at first i thought it was the bulbs, so i replaced them. but, that didnt work. neither the low nor high beam works on the headlight. i checked the fuse for the right headlight, it was ok but i replaced it just in case. still no luck. i was wondering what other fuses/electrical stuff i should look at.
You need to pull the connector off the headlight and see if you have power and ground.
