Old 05-05-2004, 11:11 PM   #1
Kyle
Guest
Posts: n/a
I have an 1987 Supra Turbo, and the other day i was driving it. i was in second gear and my RPM's just droped, so i went to first gear and it just died. when i had an jeep wrangler and i used to go off roading it used to do the same when i got it all soaken wet. I've check all the fuses, checked the coil, even tried to put ether in the intake to see if it start and it wont. It will turn over like it normal does and it's not fast. It has pressure because it doesn't turn fast. i have no idea what it could be, it just doesn't wanna run. plz help thank you
Kyle
Having some Troubles... 87MGE MKIII Supra 4 05-03-2008 08:03 AM
Knock Sensor Troubles!!!! Draftinwitjr3815 Non-Generation Specific Questions 0 03-18-2008 10:16 PM
engine troubles yota_head MKIII Supra 4 02-21-2007 05:58 AM
map ecu troubles turbotaco MKIII Supra 2 01-03-2006 07:41 PM
smog troubles tonster MKII Supra 2 09-24-2005 10:21 PM
