Old 06-23-2004, 08:43 AM   #4
suprra_girl
Guest
Posts: n/a
ok knowing supras and it being an 87 it is most likely an automatic... how a gearbox changing from gear to gear by itself causing the car to die i don't know, i have never in all my experience heard of this, either he has blown off a vacuum hose or got a leak after the air flow meter causing erratic idle
also another very good idea would be to check your cambelt, when was the last time it was replaced? has it snapped?
check your diagnostics first and check your cambelt, check for leaks, replace air flow meter if still no luck reset the ecu
Cheers
Suze
Having some Troubles... 87MGE MKIII Supra 4 05-03-2008 08:03 AM
Knock Sensor Troubles!!!! Draftinwitjr3815 Non-Generation Specific Questions 0 03-18-2008 10:16 PM
engine troubles yota_head MKIII Supra 4 02-21-2007 05:58 AM
map ecu troubles turbotaco MKIII Supra 2 01-03-2006 07:41 PM
smog troubles tonster MKII Supra 2 09-24-2005 10:21 PM
